![]() | Home > Technical (L322) > engine system fault TDV8 |
SFM Member Since: 19 Feb 2012 Location: dordogne Posts: 258 ![]() ![]() ![]() |
Forgot to mention, although it's only done 5k since service, the service date is flashing up also, and has been for a while, are the two connected?
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8750 ![]() ![]() ![]() |
Battery, then top turbo hoses as a place to start. As these are easy to access, replacement instruction in the wiki. Take them off and check for cracks or splits, especially under the protective mesh.
NMJ
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16339 ![]() ![]() ![]() |
If it's doing it at start up when cold it could be the start of an EGR issue! Best not to cane it I case you do damage to the turbos... Get codes read asap my friend... |
Craig has a point, and is more likely the problem, but worth checking the easy stuff first.
Exactly... Hopefully it will be a pipe split BUT!!! Don't cane it, that's important |
If it is something like the egr, will it not go into failsafe mode? |
Err, no...
In a BIG & expensive bang!!!!!!! |
That's reassuring to know |
Fault codes read my friend... Egrs are reasonable, turbos and ingested vanes are not. There is nothing that can't be fixed with a hammer😜😜
Thanks guys
Battery now fully charged again, started her up...no faults
Sql Member Since: 27 Jun 2015 Location: Poland Posts: 252 ![]() ![]() ![]() |
Did you ever get to the bottom of it? My tdv8 started to show "engine system fault" message at first morning start for a brief moment. After a second or two it dissapears and does not appear again throughout the day. 12 4.4 TDV8 Vogue
