![]() | Home > Maintenance & Mods (L322) > Tail gate seal fix |
Welshdragon Member Since: 20 Jan 2012 Location: here and there...but not where I should be Posts: 1901 ![]() ![]() ![]() |
So after reading Geoff's thread ( http://www.fullfatrr.com/forum/topic29940.html) and some help from my daughter with the jet wash I decided to see where this annoying leak is coming from once and for all.
le25dse Member Since: 15 Jan 2012 Location: Oslo Posts: 78 ![]() ![]() ![]() |
Thanks for sharing. Hope it lasts!! ----------
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16341 ![]() ![]() ![]() |
Good luck WD |
Well just to close down this thread, it rained hard last night...just checked the boot/wheel well and I can confirm that the above fix has worked, bone dry, happy days and a cheap fix too. |
gregdav Member Since: 26 May 2014 Location: just north of stafford Posts: 1077 ![]() ![]() ![]() |
Well done wd. Another good cheap fix |
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3896 ![]() ![]() ![]() |
Mines with the dealer at the moment for the same fix, hopefully they'll fit a new seal but if not I'll be following suit |
I read on another well known social media thread I'm on, a chap was asking about the boot seal.....and thought ah yes my cheap fix...... well as a long time has gone by I can confirm no water has entered the rear boot or spare wheel well.
MR GLOVER Member Since: 03 Jan 2015 Location: grimsby Posts: 606 ![]() ![]() ![]() |
Did this on mine top fix |
Fair play sir, glad it work too |
PaulTyrer Member Since: 22 Jul 2013 Location: Devizes, Wiltshire Posts: 1261 ![]() ![]() ![]() |
Somehow related to this, we have a leak somewhere on the drivers door area, the A pillar interior trim is getting wet and the footwell carpet wet. We had a new windscreen fitted a couple of months back (genuine LR glass) by Autoglass (I watched them fit it!), but we still have a leak, I'm convinced that it is the door seals but cant convince SWMBO that its the seals. Passenger side is perfect but the door is not used as much as the drivers side. Am I right in my thinking?? |
Zirconblue Member Since: 16 Apr 2015 Location: Kent Posts: 1277 ![]() ![]() ![]() |
or it could be from a blocked sun roof drain. |
I would have a go at cleaning out the sunroof tubes as well, but as you've had a new screen it may be that, I had a Land Cruiser that had a perfect screen but leaked at the passenger side, no matter what I sealed it to try and fix it the passenger foot well was always wet. |
