Home > Maintenance & Mods (L322) > Tail gate seal fix
Welshdragon
Wales 2003 Range Rover Vogue 4.4 V8 Monte Carlo Blue
Tail gate seal fix
So after reading Geoff's thread ( http://www.fullfatrr.com/forum/topic29940.html) and some help from my daughter with the jet wash I decided to see where this annoying leak is coming from once and for all.
I took out the wheel well cover and cubby hole covers as well as the trim that was damp on the rights side near the lower tail gate. I was armed with a torch and roll of blue roll tissue in the ready for the leak........and hay presto it didn't take long for the water to come in, not between the seal and the tailgate but the body work and seal tracking through!
Now I guess it was the top right corner was the issue, so I re seated all of the seal and silicone sealed the lip that the seal slides onto the body with a non set sealant that I used to use for sealing the distributer on the Land Rover 90 comp truck when deep wading.
Re-fitted the seal and a jet wash test on fine spray again to see if it leaks and it passes the test, but the real test will be when it rains properly.....which wont be long living in Wales Laughing
A few pictures to show what I found, might not fix other FF's but they do seem to like washing the spare wheel with the amount of threads on this issue!
Starting to leak through
Lower in the boot from last nights rain
After 5 minutes of the jet wash
The silicon sealant compound
Sealing up and did all the seal.
So if this works and have nothing to loose its worth trying this first, might save a few pennies !! If it dont work.......burn it!
If the IId tool cant fix it.......burn the FF.
If the FF cant be fixed......buy a Land Cruiser!
If the LC cant be fixed..............................................BUY a horse !!
Post #309463 31st Jan 2015 1:59pm
le25dse
Norway 2014 Range Rover Vogue TDV6 Loire Blue
Thanks for sharing. Hope it lasts!! ----------
2014 tdv6 (ex. 2004 td6, 1997 2.5 dse)
Post #309615 1st Feb 2015 10:22am
Welshdragon
Thanks, hope so will up date when we have had a good amount of rain to really test the fix. If it dont work.......burn it!
Post #309718 1st Feb 2015 3:31pm
Good luck WD Thumbs Up
Post #309729 1st Feb 2015 3:57pm
Welshdragon
Well just to close down this thread, it rained hard last night...just checked the boot/wheel well and I can confirm that the above fix has worked, bone dry, happy days and a cheap fix too. Mr. Green If it dont work.......burn it!
Post #312565 14th Feb 2015 9:23am
gregdav
England 2005 Range Rover Vogue Td6 Bonatti Grey
Well done wd. Another good cheap fix Thumbs Up Bow down Bow down Bow down
Post #312644 14th Feb 2015 6:10pm
supershuttle
Mines with the dealer at the moment for the same fix, hopefully they'll fit a new seal but if not I'll be following suit Very Happy Geoff
Post #312659 14th Feb 2015 7:54pm
Welshdragon
I read on another well known social media thread I'm on, a chap was asking about the boot seal.....and thought ah yes my cheap fix...... well as a long time has gone by I can confirm no water has entered the rear boot or spare wheel well.
So it maybe worth the above fix before splashing out for a new one. Worth a try Imo. Thumbs Up If it dont work.......burn it!
Post #345724 2nd Sep 2015 7:05pm
MR GLOVER
United Kingdom 2005 Range Rover Supercharged 4.2 SC V8 Buckingham Blue
Did this on mine top fix Thumbs Up
Post #345727 2nd Sep 2015 7:13pm
Welshdragon
Fair play sir, glad it work too Thumbs Up Thumbs Up If it dont work.......burn it!
Post #345735 2nd Sep 2015 7:44pm
PaulTyrer
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Cairns Blue
Somehow related to this, we have a leak somewhere on the drivers door area, the A pillar interior trim is getting wet and the footwell carpet wet. We had a new windscreen fitted a couple of months back (genuine LR glass) by Autoglass (I watched them fit it!), but we still have a leak, I'm convinced that it is the door seals but cant convince SWMBO that its the seals. Passenger side is perfect but the door is not used as much as the drivers side. Am I right in my thinking??
Post #345756 2nd Sep 2015 9:08pm
Zirconblue
or it could be from a blocked sun roof drain.
Post #345775 2nd Sep 2015 11:16pm
Welshdragon
I would have a go at cleaning out the sunroof tubes as well, but as you've had a new screen it may be that, I had a Land Cruiser that had a perfect screen but leaked at the passenger side, no matter what I sealed it to try and fix it the passenger foot well was always wet. Big Cry, new screen and seal sorted it out in the end.
Try and replicate rain over the screen seal (or sunroof) where you think it leaks in.
Never heard about a door seal leaking though, keep us posted on out come. Thumbs Up If it dont work.......burn it!
Post #345807 3rd Sep 2015 8:50am
