Home > Technical (L322) > Locked out !
J evro
England 2008 Range Rover Vogue SE TDV8 Stornoway Grey
Locked out !
Strange thing just happened for the first time , locked the car by remote fob went to pay for fuel and on return fob would not unlock doors ?
After about 12 attempts it unlocked and started as normal
Any ideas why this would happen, fob battery is almost new ?
Cheers
Post #309026 29th Jan 2015 2:46pm
PaulTyrer
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Cairns Blue
Any overhead power lines around?
I've been told by LR Dealers that it can interfere with the remote.
Post #309035 29th Jan 2015 3:26pm
it happens, supermarket car parks seem to be a popular place where this occurs.. ... - .- -.
Post #309043 29th Jan 2015 3:36pm
J evro
Really .....
I was in a shell station forecourt ( been there many times Rolling with laughter and never happened before )
Post #309052 29th Jan 2015 4:01pm
J evro
I think the power lines across the road from me repost my posts in the wrong sections every time also Whistle
Post #309053 29th Jan 2015 4:03pm
Anything which operates on the fob frequency can cause interference and stop the locking signal getting through, I had it once in waitrose car park in Malvern, think it was something to do with the remote trolley collecting machine, as when that had naffed off it unlocked!
Unlikely to be the car. There is nothing that can't be fixed with a hammer😜😜
Post #309054 29th Jan 2015 4:15pm
johnboyairey
i hope it wasnt caused by a scanner scammer scrote, sucking in your keyfobs signal, -in a van parked nearby...and storing it for dirty trickery..... could you not have tried putting the key in the slot? you know, like your front door at home...?
maybe your model is too technical for my simple life.. Shocked
Post #309064 29th Jan 2015 4:59pm
jakebullet64
United Kingdom 2003 Range Rover Vogue 4.4 V8 Santorini Black
Duff Battery in the fob?
Has anyone else noticed the slight delay between pressing a button on the fob and the led lighting up or is it just mine? 2003 Range Rover Vogue 4.4 on Gas
1961 88" 2.25 diesel - George
Gone - 1997 3.9 V8i Discovery - Burt
Post #309087 29th Jan 2015 7:08pm
CCTV camera's used to do it to P38's all the time Yawn
Recovered many from carparks (always parked under a CCTV mast!)
Post #309105 29th Jan 2015 7:48pm
J evro
If I change the battery just I test that theory does it then need resetting / recoding?
Post #309257 30th Jan 2015 2:39pm
sasdiscos
United Kingdom 2010 Range Rover Vogue SE TDV8 Zambezi Silver
Shell wifi in particular interferes with the lr remotes.
Steve You remind me of a young me, not much younger mind, perhaps even a little older!
Post #309259 30th Jan 2015 2:41pm
Andy B
No re-coding, just straight replacement. Did mine last week Thumbs Up
Type is CR2032 SDV8 AB MY 2019
SDV8 VSE MY 2015 - Gone
5.0 S/C AB MY 2010 - Gone
4.2 S/C VSE MY 2006 - Gone
Post #309261 30th Jan 2015 2:48pm
jarv
Had some building work done last year. The lorry delivering the materials had a remotely operated crane thing on it. Couldn't get in my car whilst he was delivering, but once he left, everything worked fine.
Post #309269 30th Jan 2015 3:54pm
mzplcg
Yep, when I worked at AT&T in Redditch our offices were under a water tower with a load of transmitters on it. Just about every car in the car park was left unlocked - nobody's tweeky locking thing worked Laughing
Post #309271 30th Jan 2015 4:00pm
J evro
Thanks chaps Thumbs Up
Post #309321 30th Jan 2015 7:07pm
