Home > Technical (L322) > Locked out !
ebajema
If you check where the receiver of the signal is (if I remember correctly, at the B-pillar) and use the key very close to the receiver, the signal drownout (if that is causing the problem) may not be as bad or better the key signal is stronger. MY 2010 5.0 SC Galway green and sand interior!!
Post #309392 31st Jan 2015 12:13am
the key fob receiver is located at the top of the upper tailgate and uses the rear screen as an antenna so if you do have an unlocking problem then try putting the key fob close to that point..... ... - .- -.
Post #309434 31st Jan 2015 10:52am
i was searching for something else and came across the possible reason why the OP's key remote didnt work at the petrol station, apparently there appears to be a magnetic field generated by the petrol stations LPG pump's which interferes with the fobs.. ... - .- -.
Post #311103 6th Feb 2015 9:32am
J evro
England 2008 Range Rover Vogue SE TDV8 Stornoway Grey
Thanks Stan, glad I'm not on LPG then Wink
Key has worked fine ever since Wink
Post #311167 6th Feb 2015 2:10pm
