Having twice painted the back boxes on two RR in recent years by using a Halford Satin black spray can, I've found that if you try and clean the box after it has been sprayed, the paint flakes off here and there.
So, I've just brush painted the back box with Hammerite smooth finish satin black. It needs no primer and the previous Halfords satin spray becomes the undercoat.
Prepared it by cleaning the box with soapy water and a cloth. The cloth removed any flaky bits of paint as it was one of those bug remover type finishes. Then rinsed with water, let it all dry and used a paint brush to paint on the Hammerite satin.
Took about an hour, finish looks as good as a spray can and no overspray or need to mask areas off.
I don't think it will flake off as easy. Time will tell.
