Home > Maintenance & Mods (L322) > Front Mud Guards not quite flush to bodywork
scwilson
United Kingdom 2003 Range Rover Autobiography 4.4 V8 Epsom Green
Folks,
I spent a few hours fitting some front mud guards to my Range Rover. They are Land Rover mud guards, the previous owner had sidebars and front mud guards that were removed so the necessary brackets were left along with the two necessary holes in each side of the plastic panel. I checked with the template from Land Rover that the holes were exact and they were.
So I fitted them but have noticed they are not quite snug to the bodywork, I tried bending slightly some of the brackets but it made no difference, almost as if the rubber/plastic has a slight lip on it.
Question is, how do others fit? Do you have this issue? I was wondering whether it's worth me heating the plastic a little with a hair dryer and bending in??
Front Right ...
Front Left ...
Post #308089 26th Jan 2015 11:27am
n1cktdv8
2 words...
Silicone sealant Whistle Is this where I put the car details and a bit about myself ?........
Post #308093 26th Jan 2015 11:29am
scwilson
I didn't think of that Smile
Was just puzzled as to why there are slight gaps. I think the perfectionist in me ... I need to take into account it is almost 12 years old.
Post #308109 26th Jan 2015 12:08pm
You may need to take it off and try again. Its only a lighweight panel and need to be located exactly to look right but can easily be moved about using finger power. Silicone NO Shocked
Post #308110 26th Jan 2015 12:13pm
they look like they need to come down vertically a touch so the profile fits better.. ... - .- -.
Post #308111 26th Jan 2015 12:21pm
n1cktdv8
n1cktdv8 wrote:
2 words...
FFS....it was a joke... Bow down Is this where I put the car details and a bit about myself ?........
Post #308112 26th Jan 2015 12:24pm
scwilson
Not sure they can come down any lower as the holes were already cut in the panel (perfect alignment with the Land Rover template) and the brackets already in place. The panel is so flimsy I worry about breaking it or any of the flimsy plastic brackets on the back of it. I spent a while yesterday trying to adjust to no avail Sad
Post #308139 26th Jan 2015 1:21pm
scwilson
One option I have is to remove the old brackets and fit the new ones supplied with the mud guards. I didn't bother fitting the new ones since the old ones were in place already.
I also noted that you needed to remove some of the trim underneath the wing for this and not having done this before, I didn't really want to. Do you think fitting the new brackets will correct this or can I simply adjust (bend) the brackets that are there to close this gap?
As Stan mentions, maybe they need to drop vertically ever so such but I'm not sure how I can do this as they are fitted into the holes of the removable plastic wing piece.
Post #308165 26th Jan 2015 2:17pm
i've been looking for front mudflaps and i've noticed that there are two different types of mounting brackets , maybe you need to swop yours? ... - .- -.
Post #308170 26th Jan 2015 2:24pm
scwilson
Mine were from Land Rover themselves. The brackets that were already on my RR aligned with the holes so I assume if there were any changes in the brackets it would have been highly noticeable.
As I say, I did not remove the plastic inside the inner wing above the wheel as per the instructions as I was worried in breaking something and also, the wheel may need to come off and/or crank it up to off-road height.
If I push the mud flaps towards the vehicle then it fits flush, but take the pressure off and it goes back to having the slight gap.
Post #308179 26th Jan 2015 3:14pm
Dolphinboy
Mine are just like yours, with a slight bend away from the bodywork. Think it is more to do with the plastic warping. Hair-dryer may do the trick.
Post #308182 26th Jan 2015 3:22pm
scwilson
Are OK, weird isn't it?
I spent what I thought was 2 hours but was actually 4 as my wife confirmed Shocked
I am fairly sure it is the plastic, these are new mud guards so with time perhaps they will settle or I can try a hair dryer. Never in my time of owning a car have I ever seen such a Censored to fit set of front mud guards. As I say, I'm reluctant to start again, take out the old brackets and fit the new identical ones if I'll end up in the same position. I run the risk of breaking some of the inside wing covers etc
Post #308187 26th Jan 2015 3:33pm
have you put 2 bolts in where i've marked with arrows?
there should be 2 there and another 2 coming in from the tyre side..[i think] ... - .- -.
Post #308188 26th Jan 2015 3:36pm
scwilson
Yes, there are two bolts that fix to the removable plastic panel.
I basically took the panel off, fitted the mud guard to it using the two bolts with washers and nuts on each side. Then, after popping the panel back in with the newly attached mudguard, fixed to the brackets using 4 screws on the inside of the wheel arch.
Post #308192 26th Jan 2015 3:48pm
scwilson
http://topix.landrover.jlrext.com/topix/co...d%20guards
Post #308194 26th Jan 2015 3:54pm
