Home > Maintenance & Mods (L322) > Front Mud Guards not quite flush to bodywork
Googsy
Don't put screws in if you ever want to remove them though Thumbs Up Present :2008 TDV8 HSE
Gone Audi A5 2.7TDI
Gone Discovery 3 HSE
Gone Mercedes CLK
Gone Range Rover 2.5 DSE
Post #308199 26th Jan 2015 4:07pm
scwilson
United Kingdom 2003 Range Rover Autobiography 4.4 V8 Epsom Green
Do you mean rusting and the heads coming off?
Post #308200 26th Jan 2015 4:08pm
Googsy
No if you use screws these are secured by drilling into plastic panel . Once removed (flaps) you will have holes in the panel. I fitted flaps thinking the car looked best with them but on reflection I prefer no flaps but it proved too late as I had drilled holes. If you must have them leave them fitted as they are that way should you ever want to remove them you wont have any holes to cover up. Present :2008 TDV8 HSE
Gone Audi A5 2.7TDI
Gone Mercedes CLK
Post #308215 26th Jan 2015 4:40pm
scwilson
I might try a hair dryer then to see if I can shape them in a little.
Any thoughts on a heat gun or would hair dryer suffice?
Post #308220 26th Jan 2015 4:55pm
scwilson
Ok resolved. Took both off, fitted some number plate double side tape inside the mud guard to hold to the bodywork.
Brackets were OK, messing around with the brackets would have made no difference. They are now snug against the bodywork. It was actually the rubber/plastic edges of the mud guard that didn't seem flat and ever so slightly curled.
Actually noticed a 2008 TDV8 RRFF today that had much worse gaps than mine originally had on the front and rear so it seems like a tricky thing to fit snug, or over time they just weather.
Post #308490 27th Jan 2015 2:54pm
good job sir Thumbs Up ... - .- -.
Post #308495 27th Jan 2015 3:16pm
PaulTyrer
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Cairns Blue
stan wrote:
Must admit, was thinking of fitting them to mine but I dont like them with the two white arrows on!!
Can you get them without??
Post #308523 27th Jan 2015 4:50pm
Thud
Laughing ... - .- -.
Post #308524 27th Jan 2015 4:52pm
Ianmaney
United Kingdom 2011 Range Rover Vogue SE TDV8 Mariana Black
Its built by Land Rover, its supposed to have gaps !!!! Laughing Semper in merda sumus, solum altum variat !!
Current: 2011 4.4 TDV8 Vogue SE
Last one: 2003 3.0 TD6 Vogue
Post #308656 28th Jan 2015 8:30am
Rolling with laughter Rolling with laughter Rolling with laughter Bow down Thumbs Up
Post #308672 28th Jan 2015 10:27am
