![]() | Home > Camping, Caravanning and Holidays > FFRR or SWMBOs skoda..... |
CEEGEE Member Since: 20 Mar 2013 Location: Yorkshire Posts: 685 ![]() ![]() |
Say no more |
FF anytime, anything else no way. Just make sure that everything is ticketyboo and pray to whatever deity you fancy while driving |
No, it has to be to the right deity. If you pray to the wrong one, no only will you break down, you will also burn in hell. |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16306 ![]() ![]() ![]() |
Or come home a "changed man" David |
Only if you break down on the road to Damascus Craig, and not many on here are choosing that destination these days! |
You're right, you most definitely need a St. Christopher (hope I spelled it correct in English) dangling from your mirror and you need a friend or family member to buy you an "angel" (tradition in the motorbike world) that needs to be fitted by that friend in a place to ward of the road devils. It usually is a little bell |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8678 ![]() ![]() ![]() |
Had a look at the hose under the expansion that Alisair mentioned. It is indeed rubbing, but in my case on some part f the wiring harness, it's on its way but should be good for a fair few more miles. When I get a chance I'm going to wrap some amalgamating tape round it to prevent it going any further.
