Home > Technical (L322) > Seat bottom foam replacement
funnyguy1
United States
Has anyone replaced the foam seat bottom on the front seats? Is is expensive. I have the heated/cooled.Thx! Mike
Post #304905 14th Jan 2015 3:05am
you asked this back in feb 2014, havnt you done it yet Laughing Wink
http://www.fullfatrr.com/forum/topic23738....=seat+foam ... - .- -.
Post #304918 14th Jan 2015 8:32am
Blimey Stan, do you remember ALL the posts.......!!!!! Pete
Post #304938 14th Jan 2015 11:01am
4 bolts remove the seat from the car then its just a few fixings and the bottom (seat base) comes away as a complete unit... There is then a couple of those squeezed metal rings holding the middle of the leather to the swab Thumbs Up
Very very simple job sir Thumbs Up
Most people don't realise the base swabs fit either side... So, to get twice the wear out of your seats, you can simply remove both bases and swap OS & NS over Thumbs Up
Post #304944 14th Jan 2015 11:23am
funnyguy1
United States
Thanks Stan! Wow, i forget I asked last year. Going to try it again. Mike
Post #305072 14th Jan 2015 4:24pm
milesg
United Kingdom 2010 Range Rover Vogue SE TDV8 Santorini Black
Craig, just to confirm, do you have to take out the whole seat first (undoing the 4 bolts on the floor) then remove the base, or does the base come away separately? Do you swap covers or the whole base including heater / fan etc) I remember you mentioning this to me when we met, I want to keep mine looking fresh. You do say very very simple and I beleive I am...!
Thanks in advance chap. Miles Now sold - MY2010 Range Rover Vogue SE - Santorini Black & Ivory Leather
Post #308106 26th Jan 2015 12:04pm
DaveK
United Kingdom 2013 Range Rover Vogue TDV6 Corris Grey
Surely the seat controls will be on the wrong side though ?
Post #308378 26th Jan 2015 11:50pm
the controls are attached to the surround not the squab, the actual squab is separate. There is nothing that can't be fixed with a hammer😜😜
Post #308381 27th Jan 2015 12:01am
milesg
so full seat out..! Now sold - MY2010 Range Rover Vogue SE - Santorini Black & Ivory Leather
Post #308536 27th Jan 2015 5:45pm
Weegie
Deleted John
GAP iiD BT-Sold
Post #317490 11th Mar 2015 3:35pm
verydisco
Anyone ever done it (with pics) please? l=Oo\________/oO=l l:OolΞΞΞΞΞΞΞloO:l
Current
Previous:
Post #341216 7th Aug 2015 10:24pm
DaveK
I'd like to see the seat base swop in pics as well if any one ever does it.
Post #341219 7th Aug 2015 11:43pm
JCW
United Kingdom 2010 Range Rover Autobiography TDV8 Santorini Black
I did this job a couple of years ago on a 2007 (heated / cooled seats) & as Craig says, it's pretty straightforward. Seats do have to come out but from there its just a case of undoing a few fixings before you can remove the base cover / foam, which comes off together. The cover is attached to the foam using hog rings, you can snip these off but need new hog rings & hog ring pliers to re-attach the new foam, I'd actually say this is the trickiest part as some are quite awkardly positioned, but overall very do'able if you take your time. Reassembly is just the reverse from here. I also fitted new leather covers. No photo's I'm afraid, but am planning this job again on another RR so will photograph & post when I get around to it.
Post #341229 8th Aug 2015 8:19am
mattstevenson2005
United Kingdom 2003 Range Rover Autobiography 4.4 V8 Java Black
i did mine a few months ago and the hog rings are a pain in the Censored i decided to scrap the rings and use really strong thin cable ties worked treat!
Matt
Post #341292 8th Aug 2015 4:33pm
Danwilderspin
sorry to drag this up but where did you get the foams and any idea what was paid?
Post #400997 18th Aug 2016 1:51pm
