Home > Maintenance & Mods (L322) > rear heater |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35419 |
is there not a switch on the front console that switch's the heat to the rear on and off?..would it be that maybe/ ... - .- -.
25th Nov 2013 10:33am |
andyleeds Member Since: 31 Dec 2010 Location: west yorks Posts: 952 |
its the speed of the fan rather that the heat setting..... it should be variable controlled by a dial.... but it either full on or off, hence i think that its the resistor...
25th Nov 2013 10:42am |
understood.. ... - .- -.
25th Nov 2013 10:49am |
question is where does it go? |
25th Nov 2013 10:53am |
anything in the WM? ... - .- -.
25th Nov 2013 10:57am |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3979 |
Given the fan is controlled by a switch at the rear of the consol and the fan is located at the rear of the consol I would hazard a guess that the resistor is located somewhere near to the switch / fan.
25th Nov 2013 11:53am |
BILLTU Member Since: 23 Jan 2013 Location: Glos Posts: 73 |
This is wha the Desription and Operation section of the WM says
25th Nov 2013 11:54am |
cool, will have a look and see what i can see....
25th Nov 2013 3:45pm |
Lous2311 Member Since: 11 Jan 2015 Location: New Orleans Posts: 2 |
Andy did you find where the rear blower output stage located? I need to change mine and any tips would be great. |
11th Jan 2015 6:16pm |
rej Member Since: 06 Jan 2014 Location: Stevenage Posts: 496 |
My rear blower blows hot or warm air unless the blower is turned up to full then it will blow hot or cold depending on temp setting. Is this likely to be the resistor? There is a difference between knowing your sh!t and knowing you're sh!t
12th Jan 2015 4:14pm |
Rear blower output stage or FSR location. I had to unbolt the center console and lift the back up to get to it. It's screwed into the bottom right of the blower in the center console.[[img]img]
14th Jan 2015 2:16am |
pics added..
14th Jan 2015 7:47am |
