![]() | Home > Technical (L322) > Headlight warning buzzer |
RCusden Member Since: 12 May 2012 Location: NarberthPembrokeshire Posts: 186 ![]() ![]() |
Hi, I'm trying to find out should my ffrr have a buzzer warning for when the lights are left on and the key is out of the ignition and the door is open ? Mine just has the message come up on the dash is this right ?
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8352 ![]() ![]() ![]() |
mine just does a "bong of doom" just a single one.... keep meaning to stick the IID tool in and see what the options are... Pete
Ah cheers Pete looks like mine has been switched off as it can bong when you don't want it to. |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3657 ![]() ![]() |
Easy way of checking the Bong Of Doom is to put the key in the ignition and without turning it open the door, all merry Bongs should ensue, not just one, it fact more like a pink fit |
All off by default on mine .... which was a relief! I mean :
Tell me about it! There are times when you are in a hurry to get inside (mainly having been caught in traffic with the services in your rear view mirror |
I don't get that when the key is in the ignition with the door open, which sounds like a blessing. Looks like I will have to get an iid tool and look at what the last owners have set things as.
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16306 ![]() ![]() ![]() |
Or the "bonger" in your dash binnacle has failed sir! |
I get the boing when going between hi and low ratio and had heard the boing plenty when the suspension compressor was playing up. Who knows it must be one of the joys of owning a range rover.
I think you might be on to something with the "bonger" being broke, as I had to use low ratio yesterday and no bong. Next question where is it ???
Starberg Member Since: 08 Jan 2015 Location: Karlskrona Posts: 70 ![]() ![]() ![]() |
I get several bongs and warning message: key still in ignition. Does anyone know how to shut that anoying sound of? Cheers L322 Vogue 2003 |
Err, |
Buy yourself an iid tool sir, you can switch them off via the CCF files sir ![]() |
Got an all comms but seems indeed that i need an IID tool for this job, okey thanks! L322 Vogue 2003 |
