Home > Technical (L322) > Dash display - 2006 TDV8
DMRR
South Africa 2009 Range Rover Westminster TDV8 Stornoway Grey
Hi All,
Can anyone confirm that the 'last selected' display on the dash is supposed to stay selected on a car restart? I can't for the life of me remember if it does, but after having the battery changed it only seems to want to remember what I selected after a short stop, but next morning we are back to blank - until I reselect?
Thanks in advance Smile Land Rover Addict
XXXXXXXXXXXXXXXXXXXXXXX
Previous
XXXXXXXXXXXXXXXX
2009 5.0V8SC Autobiography
2006 4.2V8SC Autobiography
2004 4.4V8 Vogue
Post #302747 4th Jan 2015 9:09pm
do you mean the time,date,mpg,tank miles left etc?
if so yes it should stay on what you left it at.. ... - .- -.
Post #302750 4th Jan 2015 9:24pm
DMRR
Yeah....oh dear, wonder why mine isn't then Sad Land Rover Addict
Previous
XXXXXXXXXXXXXXXX
2004 4.4V8 Vogue
Post #302751 4th Jan 2015 9:25pm
sodalis
United Kingdom 2007 Range Rover Vogue SE TDV8 Tonga Green
Mine is like yours. It stays on what I set it to between short stops but reverts to blank after longer periods - possibly overnight but not checked it in detail.
Post #302869 5th Jan 2015 2:53pm
Are you using 2 different keys?
I know that there was an issue with losing radio stations etc which was caused by swapping keys. Can be fixed with a dealer software update. There is nothing that can't be fixed with a hammer😜😜
Post #302890 5th Jan 2015 5:20pm
DMRR
Used IID to clear all the errors, changed battery in keyfob. Will see what happens in the morning.
As an aside, not been here for a long while - have had a lot of fun changing every lamp over to LED (inside) and CREE (outside) and inside (bar the Bi-Xenons). Has anyone else had the pleasure of trying to change the glovebox lamp?! What a PITA!!!!
Difference between LED and CREE externally is shocking! Land Rover Addict
Previous
XXXXXXXXXXXXXXXX
2004 4.4V8 Vogue
Post #303510 7th Jan 2015 9:15pm
I think there is a Comfort or Convenience option for this in the CCF, has it always worked before? FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #303574 8th Jan 2015 2:37am
