![]() | Home > General > Do you drop the suspension when parked overnight? |
allycraven Member Since: 28 Mar 2011 Location: North Craigo, Angus Posts: 440 ![]() ![]() |
If I recall correctly, lowering to access height should be done whilst approaching the parking spot rather than when stationary to reduce stress on suspension components..
gregdav Member Since: 26 May 2014 Location: just north of stafford Posts: 1077 ![]() ![]() ![]() |
Yep it's in the handbook. |
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3870 ![]() ![]() ![]() |
I'm a bit of a lowerer (if thats a word) when costing to a stop outside the house I hit the button on the door panel. I have to say its when I remember though, because I also am a bit lanky (though not as much as Criag |
And the Semi Aniline seats in your latest car will wear at a much quicker rate too Geoff... It'll be a good habit to get into sir |
Java Jungle Member Since: 22 Mar 2010 Location: Monte-Carlo Posts: 420 ![]() ![]() ![]() |
Good to know about the column function, mine is always on....
Andy S Member Since: 16 Jun 2013 Location: Sevenoaks Posts: 1041 ![]() ![]() ![]() |
Craig
No sir it cannot I'm afraid ![]() |
Yup, that's what I thought |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8379 ![]() ![]() ![]() |
When the air suspension deflates it passes the, dry, exhaled air back through the drying medium to dry it.... it is designed with a venturi to raise the temp of the air and so aid drying so the medium is always dry for the next fill.... Not using it will cause moisture from the ambient air to saturate the medium and do damage to the pump and other parts of the system. The only thing that wears is the piston ring and these are now available for a cheap cost... The pumps get damaged when people don't recognise the symptom of slow raising, i.e. worn piston ring, and continue to let the poor compressor work it's heart out trying to fill the system.. As with most things, you have to know how it works, when it is working correctly, to recognise when it has problems... Pete I now have permission from the boss to use Y.O.L.O. Enjoy life __________________________________________________ 2014 L405 Autobiography SDV8 4.4 Loire Blue Ebony interior 2011 L322 Vogue SE 4.4 TDV8 Baltic Blue. Sold 2012 L322 Autobiography 5.0 Supercharged Ipanema Sand Sold 2002 L322 Vogue 4.4 V8 Epson Green (Fatty Offroader) Sold -Click for Project Fatty off roader- |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3660 ![]() ![]() |
I'll second that thought, mine was worn out when I brought the car, but I just thought that the slow raising was normal. It was only after it had failed and I'd fitted a new piston ring, that I realised it really was |
CEEGEE Member Since: 20 Mar 2013 Location: Yorkshire Posts: 685 ![]() ![]() |
Practicalities aside - they do look "cool" when lowered |
If I wanted something near the ground I'd have brought a Bentley, it's a 4 x 4, it's supposed to be high, so you can go were others can't! I want to be above the rest of the world and look down on them |
I have to lower mine to get in the garage so I simply hit the button when I press the button for the door but It has been mentioned here before that the car knows to go to sleep quicker in access height and when they wake to adjust their level they only try to equal out all four wheels not try to actually level to the horizon so to speak.
