Home > Technical (L322) > fbh
cowman
United Kingdom 2005 Range Rover Vogue SE Td6 Adriatic Blue
fbh
my fbh has stopped working ,the blower is running but the heater will not fire up is there any fuses i can check ,i had it scanned and it was coming up with flame detector of the glow plug not plausible,has anybody got any ideas what is wrong please
Post #302367 2nd Jan 2015 5:35pm
Martin
Site Admin
It means that the FBH has not been able to detect a flame, or the flame detector is faulty.
Post #302405 2nd Jan 2015 8:42pm
peejay
England 2009 Range Rover Vogue SE TDV8 Santorini Black
I tried mine for the first time this week since getting the FF 18 months ago! Well, there was a heavy frost on it and I thought it was a good time to try it 😊. Read the manual to make sure I knew what to do, carefully followed the instructions, held the remote at the correct angle, pressed the button for 2 seconds and saw a little red LED flash, then saw it flash red for a further 3 seconds, just as it said in the manual.............nothing happened! Tried again the next day.........still nothing?
I don't use the car every day so it's not that vital to have it working, but I just like things to work if they're meant to, so what's likely to be wrong?
Post #302454 3rd Jan 2015 8:11am
Weegie
Don't know if it is relevant but when I use the remote it flashes green and keeps flashing green when it is working. (MY2005 with T90 receiver and T91 remote).
I may be wrong but red flashes would indicate to me that the FBH isn't firing up.
I am presuming that the remote came with the car and is properly paired. If so then it I would think it is the FBH at fault. John
GAP iiD BT
Post #302462 3rd Jan 2015 9:51am
JAYBOY
weegie
Green light green flash is correct Thumbs Up 2020 Porsche Panamera Turbo Hybrid (V FAST)
2018 JCW Mini Cooper
2018 Skoda VRS
Post #302465 3rd Jan 2015 10:35am
Second'd Thumbs Up
Post #302469 3rd Jan 2015 10:47am
Lad
England 2010 Range Rover Vogue SE TDV8 Santorini Black
When I tried mine when I first got it the remote just flashed red and wouldn't start the FBH. I changed the battery in the remote and re-paired it back to the car by pulling out the FBH fuse in the rear RHS compartment. To pair it again I pulled out the fuse for about 10secs and reinserted the fuse and within 5secs pressed the remote button. I did get instructions on here so best to search on here. It was simple to do. Hopefully it just needs a battery and re-pairing. Thumbs Up
Post #302483 3rd Jan 2015 12:26pm
For basic troubleshooting, try turning it on manually from the home screen in the car - that will help narrow it down to whether the FBH is working, then you can start worrying about the remote.
Post #302486 3rd Jan 2015 12:36pm
ironhorse
United Kingdom 2003 Range Rover Vogue 4.4 V8 Giverny Green
http://www.the75andztclub.co.uk/forum/showthread.php?t=71982
http://www.the75andztclub.co.uk/forum/showthread.php?t=100297
Have a look at the sites above
Will give you a better understanding how and what they do
Fuse 59 for a early fullfat
Pull the fuse to reset, they lock out after 3 failed attempts to run
Post #302497 3rd Jan 2015 2:18pm
ajac8
United Kingdom 2013 Range Rover Autobiography SDV8 Baltic Blue
Just how warm is the inside supposed to get? When I have run mine for the max 30 mins the inside is only really just 'off cold' - You can tell its been warmed up but only just.. I appreciate the ambient temp will have a lot to do with it but does anyones cabin get 'toastie' warm so to speak? Is my FBH short changing me?
(also flashing green light every three seconds Thumbs Up ) 405 AB exec seats Baltic and Cirrus
93 RR Classic efi
Remember it's easier to get forgiveness than permission!
Gone in order:
4.4 TDV8 SE - gone to a good home
93 Classic hard dash Plymouth Blue
03 L322 Oslo Blue
2000 Disco TD5 ES Epsom Green
98 P38 Rioja Red
89 Classic Cairngorm Brown
Post #302516 3rd Jan 2015 5:27pm
Weegie
Mine gets real toasty inside. Thumbs Up SWMBO loves it. John
GAP iiD BT
Post #302521 3rd Jan 2015 6:44pm
cowman
when i press my remote the on button it lights green the motor or fan starts up the green light goes out then if i press the off it lights red turns the fan off and the red light goes out, it does not fire up it just runs the fan.
Post #302522 3rd Jan 2015 6:47pm
PaulB
2017 Range Rover Autobiography SDV8 Loire Blue
http://www.fullfatrr.com/forum/topic23111....rench+mike
Post #302600 4th Jan 2015 12:10am
I hate to state the obvious sir but, what are your heater controls set to? If they are not up high, the cabin won't warm that much... Thumbs Up
Post #302618 4th Jan 2015 8:33am
cowman
i will have to take the pcb out and send to french mike,can some one give me his address so i can send it ,thanks.
Post #302626 4th Jan 2015 10:27am
