Home > Technical (L322) > fbh |
cowman Member Since: 24 Jul 2013 Location: United Kingdom Posts: 186 |
my fbh has stopped working ,the blower is running but the heater will not fire up is there any fuses i can check ,i had it scanned and it was coming up with flame detector of the glow plug not plausible,has anybody got any ideas what is wrong please |
2nd Jan 2015 5:35pm |
Martin Site Admin Member Since: 24 Mar 2007 Location: Hook Norton Posts: 1668 |
It means that the FBH has not been able to detect a flame, or the flame detector is faulty. |
2nd Jan 2015 8:42pm |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3241 |
Don't know if it is relevant but when I use the remote it flashes green and keeps flashing green when it is working. (MY2005 with T90 receiver and T91 remote).
3rd Jan 2015 9:51am |
JAYBOY Member Since: 17 Oct 2012 Location: South Wales Posts: 2204 |
weegie
3rd Jan 2015 10:35am |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16302 |
Second'd |
3rd Jan 2015 10:47am |
Lad Member Since: 11 Oct 2014 Location: Blackburn Posts: 284 |
When I tried mine when I first got it the remote just flashed red and wouldn't start the FBH. I changed the battery in the remote and re-paired it back to the car by pulling out the FBH fuse in the rear RHS compartment. To pair it again I pulled out the fuse for about 10secs and reinserted the fuse and within 5secs pressed the remote button. I did get instructions on here so best to search on here. It was simple to do. Hopefully it just needs a battery and re-pairing. |
3rd Jan 2015 12:26pm |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7966 |
For basic troubleshooting, try turning it on manually from the home screen in the car - that will help narrow it down to whether the FBH is working, then you can start worrying about the remote. |
3rd Jan 2015 12:36pm |
ironhorse Member Since: 13 Dec 2013 Location: birmingham Posts: 355 |
http://www.the75andztclub.co.uk/forum/showthread.php?t=71982
3rd Jan 2015 2:18pm |
ajac8 Member Since: 04 Oct 2011 Location: Shakespeares County Posts: 1661 |
Just how warm is the inside supposed to get? When I have run mine for the max 30 mins the inside is only really just 'off cold' - You can tell its been warmed up but only just.. I appreciate the ambient temp will have a lot to do with it but does anyones cabin get 'toastie' warm so to speak? Is my FBH short changing me?
3rd Jan 2015 5:27pm |
Mine gets real toasty inside. SWMBO loves it. John
3rd Jan 2015 6:44pm |
when i press my remote the on button it lights green the motor or fan starts up the green light goes out then if i press the off it lights red turns the fan off and the red light goes out, it does not fire up it just runs the fan. |
3rd Jan 2015 6:47pm |
PaulB Member Since: 17 Jul 2011 Location: Hampton Posts: 877 |
4th Jan 2015 12:10am |
I hate to state the obvious sir but, what are your heater controls set to? If they are not up high, the cabin won't warm that much... |
4th Jan 2015 8:33am |
i will have to take the pcb out and send to french mike,can some one give me his address so i can send it ,thanks. |
4th Jan 2015 10:27am |
