Home > Technical (L322) > Tailgate issue |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35377 |
catchs ? ... - .- -.
28th Dec 2014 10:56am |
Jammer600 Member Since: 31 Mar 2013 Location: Bath Posts: 212 |
By catch's you mean the black things on either end? If I push the release button they both move as if powers pressent👍 |
28th Dec 2014 11:00am |
paulmoran2 Member Since: 27 Nov 2013 Location: Leeds Posts: 1422 |
Had the same with mine...had to adjust the keep (the bit that is on the car not the tailgate) as the latch on the tailgate wasn't hooking the keep correctly, leaving one side loose.
28th Dec 2014 11:20am |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16298 |
Jammer, first job to do is to look at the top of the catches... There is a "pull up" plastic catch on the top! with the lower tailgate open, put your finger underneath and lift the two catches up... Then close the lower tailgate (without slamming it) and see if both catches lock... If they do now... You have a catch lock issue sir... If no difference then you probably have an alignment issue sir... |
28th Dec 2014 11:39am |
jakebullet64 Member Since: 28 May 2014 Location: Wolverhampton Posts: 259 |
I had this exact problem today at the shops.
28th Dec 2014 8:00pm |
Thanks all, craig, if if move the plastic bit, it the closes properly, I snapped the one off the other side last year but that one seems to work 👍
1st Jan 2015 8:35am |
