Home > Maintenance & Mods (L322) > Diff question ?
birchyman71
United Kingdom 2008 Range Rover Vogue TDV8 Java Black
Diff question ?
Just checked the fluid levels in both diffs and front took 0.3l and the back took about 0.5 l to fill them neither of them has a leak anywhere so either they haven't been filled correctly in the past or the oil has disappeared , so a question for the experts , is it normal for the fluid level to drop over time with no visible leaks ? Cheers .
Post #300097 20th Dec 2014 4:35pm
The diffs take a set quantity of oil, and it seems that this is not enough to make it come out of the holes. Basically there is nowhere for the fluid to go or get used up.
To refresh the oil you drain it down and put in a set amount as given in the workshop manual👍 There is nothing that can't be fixed with a hammer😜😜
Post #300105 20th Dec 2014 5:13pm
birchyman71
Thought it couldn't go anywhere, but thought like most boxes the oil should trickle out the fill plug, I'll drop the fluids and refill them with the right amount after Xmas . Thanks for that
Post #300144 20th Dec 2014 8:53pm
See here for quantities
http://www.fullfatrr.com/wiki/Recommended_Lubricants
Listing for the td6 shows tyk50070 for the rears, but afaik this is the fluid for the locking rear diff (Castrol carbon) but the rest of the listing is the same spec as the front tyk500010 There is nothing that can't be fixed with a hammer😜😜
Post #300168 20th Dec 2014 11:54pm
Nomad
United Kingdom 2012 Range Rover Autobiography 5.0 SC V8 Zermatt Silver
The 3.6TDV8 isn't specifically listed. Is it the same as the 3.0L? 2012 5.0L S/C
Previous:
3.6 TDV8
4.4 HSE
P38 4.6 HSE
Classic 3.9
90 County
Series3 Lightweight
Post #300193 21st Dec 2014 8:09am
Tdv8 quantities on this thread.
http://www.fullfatrr.com/forum/topic29158.html There is nothing that can't be fixed with a hammer😜😜
Post #300199 21st Dec 2014 9:13am
Nomad
Thanks! That link is for the rear diff - quantity similar to the 3.0L. Can we assume 3.6L is also similar to the 3.0L for the front? 2012 5.0L S/C
Previous:
3.6 TDV8
4.4 HSE
P38 4.6 HSE
Classic 3.9
90 County
Series3 Lightweight
Post #300203 21st Dec 2014 9:58am
Front diff on tdv8 From rave: 0.75L refill 0.8L from dry. Castrol SAF XO - 75w/90 so same as td6.
Post #300228 21st Dec 2014 11:46am
Nomad
Thumbs Up Thumbs Up 2012 5.0L S/C
Previous:
3.6 TDV8
4.4 HSE
P38 4.6 HSE
Classic 3.9
90 County
Series3 Lightweight
Post #300230 21st Dec 2014 12:14pm
