Home > Maintenance & Mods (L322) > Diff question ? |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8645 |
The diffs take a set quantity of oil, and it seems that this is not enough to make it come out of the holes. Basically there is nowhere for the fluid to go or get used up.
20th Dec 2014 5:13pm |
birchyman71 Member Since: 18 Feb 2013 Location: stockton on tees Posts: 147 |
Thought it couldn't go anywhere, but thought like most boxes the oil should trickle out the fill plug, I'll drop the fluids and refill them with the right amount after Xmas . Thanks for that |
20th Dec 2014 8:53pm |
See here for quantities
20th Dec 2014 11:54pm |
Nomad Member Since: 26 Oct 2011 Location: Ringwood, Hants Posts: 300 |
The 3.6TDV8 isn't specifically listed. Is it the same as the 3.0L? 2012 5.0L S/C
21st Dec 2014 8:09am |
Tdv8 quantities on this thread.
21st Dec 2014 9:13am |
Thanks! That link is for the rear diff - quantity similar to the 3.0L. Can we assume 3.6L is also similar to the 3.0L for the front? 2012 5.0L S/C
21st Dec 2014 9:58am |
Front diff on tdv8 From rave: 0.75L refill 0.8L from dry. Castrol SAF XO - 75w/90 so same as td6.
21st Dec 2014 11:46am |
2012 5.0L S/C
21st Dec 2014 12:14pm |
