![]() | Home > Technical (L322) > Fan not blowing on auto, but works on all steps in manual? |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35526 ![]() ![]() |
is the temp set high enough for the auto to kick in.. ... - .- -.
Seabass Member Since: 05 Feb 2014 Location: Värmland Posts: 88 ![]() ![]() |
Yes, inside is on 22c and outside is -2c 2010MY TDV8 Vogue Nara bronze / Arabica, Ivory. VW Amarok 2013 180 auto
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3879 ![]() ![]() ![]() |
Mine doesn't light up on auto but I think it does the blowing job - ohh err missis |
Well well, It seems the old FF mended itself overnight, today it works as it should again, are these the best cars ever built or what! |
Autobiography Member Since: 10 May 2011 Location: UK Posts: 925 ![]() ![]() |
It is programmed not to blow air until it has reached temperature. Mine does the same...it's so you don't get even colder! |
I remember that as well what AB just said, it waits for sufficient warm air / coolant heat is available before starting the fan. Keep an eye on the engine temp vs. the starting of the fan in auto |
