Home > General (L405) > WARNING: Bonnet catches may not catch |
Emperor Mong Member Since: 07 Jul 2010 Location: London Posts: 1435 |
Coming back from Lowestoft the other day, I was on a fast bit of dual carriageway. I had to add a bit of speed to avoid trapping a car behind a slow-moving lorry. I noticed the driver's side edge of the bonnet lift. I found the next layby and investigated. The driver's side was not secured but the nearside catch was. I'd refilled the washer bottle a few days before.
15th Dec 2014 9:55pm |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16306 |
Everyone looks slightly strange at me when i slam FFRR bonnets! I do it routinely so there can be no question... |
15th Dec 2014 10:15pm |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3979 |
Surely the bonnet catches can be adjusted so they hold securely. A coating of grease helps too. |
16th Dec 2014 8:37am |
Yes, but nothing like a good slam to make sure they are home & locked |
16th Dec 2014 9:43am |
I just drop mine from about 300mm, you get a satisfying clunk then. |
16th Dec 2014 9:46am |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35465 |
i think craig has anger issues... ... - .- -.
16th Dec 2014 9:56am |
16th Dec 2014 10:04am |
The problem on the L405 is that there are two catches. There is a satisfying clunk as you drop it and a cursory central feel will indicate that it is closed. However, you need to test both sides.
16th Dec 2014 10:12am |
There have been two catches on all RR's since the P38 days EM... Experience says a firm slam works well sir
16th Dec 2014 10:22am |
Probably worth noting Craig, the grease LR use seems to be earth shifter grade. I cleaned it all off with brake cleaner and then applied some spray white grease which doesn't go hard in the cold. The bonnet closes properly every time with no more than a 18" drop slam. |
16th Dec 2014 10:29am |
To be honest, i don't think I've seen more than half a dozen FF's with any kind of lube on them... I presumed LR did not do it
16th Dec 2014 10:38am |
Doodle Member Since: 02 Nov 2013 Location: Midlands Posts: 127 |
A warning should have appeared on your dash info. It's one you really notice.
16th Dec 2014 7:19pm |
Dean Member Since: 23 Mar 2014 Location: Glasgow Posts: 51 |
I have had the same problem on my Disco 4. Had to stop a coupe of times to resecure the passenger side catch.
17th Dec 2014 1:07pm |
