Home > General > Air con.. Do you leave yours on all year round? |
Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2265 |
Auto and 18 for me |
10th Dec 2014 5:25am |
BenjaminD Member Since: 08 Dec 2014 Location: Brisbane Posts: 19 |
Queensland Australia here, if I don't use it, I crackle and die.
10th Dec 2014 6:09am |
axle Member Since: 28 Oct 2007 Location: Perth Perth the end of the Earth Posts: 2964 |
^ It might be the computermebob thinking it can't cool your condenser enough with its own fan and kicks in the engine fan to help , only a guess but the only other sound the air com makes that you can hear easily is a slight wiring at idle when the gas runs low . 2008 MY Supercharged
10th Dec 2014 6:53am |
I always leave the AC on even in cold places. They also help making the cabin dry reducing/eliminating condensation of the windows (problem we had in northern Sweden at minus 27, AC on, problem solve). MY 2010 5.0 SC Galway green and sand interior!!
10th Dec 2014 7:33am |
rr driver Member Since: 09 Dec 2013 Location: london Posts: 181 |
Thanks will try between 18-20 this weekend. Should i leave the AC on aswell or just press Auto. 2011 5.0SC Santorini Black
10th Dec 2014 2:00pm |
AUTO with A/C on is the correct way adjusting temp only. |
10th Dec 2014 2:03pm |
Dean Member Since: 23 Mar 2014 Location: Glasgow Posts: 51 |
Yep - air con on and leave it on Auto
10th Dec 2014 2:04pm |
Set to auto but 24/25 degrees otherwise I freeze to death
10th Dec 2014 2:21pm |
Thanks for the info, 2011 5.0SC Santorini Black
10th Dec 2014 3:03pm |
Brian Member Since: 06 Dec 2014 Location: Northern Ireland Posts: 138 |
Cheers for the info, so it's a/c on + auto and 22 it is for me (there is snow on the mountains now I might even go to 23) |
11th Dec 2014 1:57pm |
ACK even the Mournes have snow FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
11th Dec 2014 3:13pm |
1959terry Member Since: 28 Apr 2014 Location: London Posts: 128 |
Leave it on. Prevents condensation and keeps the a/c seals tight.
11th Dec 2014 6:32pm |
so i drove to the west midlands and back, used the temp settings:
15th Dec 2014 12:21am |
What is the centre vent set to as I have it set to two red spots unless I'm on a long journey and then it goes to one blue spot to keep the interior a little bit cooler. FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
15th Dec 2014 12:22am |
