![]() | Home > General > Air con.. Do you leave yours on all year round? |
Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2286 ![]() ![]() ![]() |
Auto and 18 for me |
BenjaminD Member Since: 08 Dec 2014 Location: Brisbane Posts: 19 ![]() ![]() ![]() |
Queensland Australia here, if I don't use it, I crackle and die.
^ It might be the computermebob thinking it can't cool your condenser enough with its own fan and kicks in the engine fan to help , only a guess but the only other sound the air com makes that you can hear easily is a slight wiring at idle when the gas runs low . 2008 MY Supercharged
I always leave the AC on even in cold places. They also help making the cabin dry reducing/eliminating condensation of the windows (problem we had in northern Sweden at minus 27, AC on, problem solve). MY 2010 5.0 SC Galway green and sand interior!!
rr driver Member Since: 09 Dec 2013 Location: london Posts: 181 ![]() ![]() ![]() |
Thanks will try between 18-20 this weekend. Should i leave the AC on aswell or just press Auto. 2011 5.0SC Santorini Black
AUTO with A/C on is the correct way adjusting temp only. |
Dean Member Since: 23 Mar 2014 Location: Glasgow Posts: 51 ![]() ![]() ![]() |
Yep - air con on and leave it on Auto |
Set to auto but 24/25 degrees otherwise I freeze to death |
Thanks for the info, 2011 5.0SC Santorini Black
Brian Member Since: 06 Dec 2014 Location: Northern Ireland Posts: 138 ![]() ![]() |
Cheers for the info, so it's a/c on + auto and 22 it is for me (there is snow on the mountains now I might even go to 23) |
ACK even the Mournes have snow |
1959terry Member Since: 28 Apr 2014 Location: London Posts: 128 ![]() ![]() ![]() |
Leave it on. Prevents condensation and keeps the a/c seals tight.
so i drove to the west midlands and back, used the temp settings:
What is the centre vent set to as I have it set to two red spots unless I'm on a long journey and then it goes to one blue spot to keep the interior a little bit cooler. FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
