Home > General > Air con.. Do you leave yours on all year round?
Page 3 of 4 <1234>
Dean
Scotland 2007 Range Rover Vogue TDV8 Java Black
In both my Disco 4 and FFRR I leave it in Auto at 20 and that keeps it warm, very occasionally turning it up to 21 and that is in the frozen north 2006 FFRR TDV8 Vogue
2012 Discovery 4 SDV6 GS
Post #298020 9th Dec 2014 11:08pm
Sandyt
Auto and 18 for me Thumbs Up
Post #298049 10th Dec 2014 5:25am
BenjaminD
Australia 2002 Range Rover Vogue 4.4 V8 Barolo Black
Queensland Australia here, if I don't use it, I crackle and die.
Although I have to say I get a big hovering sound of them once in awhile. Turning AC off shuts down the sound immediately. No idea what the issue is.
Post #298051 10th Dec 2014 6:09am
^ It might be the computermebob thinking it can't cool your condenser enough with its own fan and kicks in the engine fan to help , only a guess but the only other sound the air com makes that you can hear easily is a slight wiring at idle when the gas runs low . 2008 MY Supercharged
Post #298052 10th Dec 2014 6:53am
ebajema
I always leave the AC on even in cold places. They also help making the cabin dry reducing/eliminating condensation of the windows (problem we had in northern Sweden at minus 27, AC on, problem solve). MY 2010 5.0 SC Galway green and sand interior!!
Post #298057 10th Dec 2014 7:33am
rr driver
United Kingdom 2011 Range Rover Autobiography 5.0 V8 Santorini Black
Thanks will try between 18-20 this weekend. Should i leave the AC on aswell or just press Auto. 2011 5.0SC Santorini Black
2009 5.0SC Santorti Black - Been stolen.
Had
2.5 DHSE P38
Alfa Romeo
BMW
Post #298145 10th Dec 2014 2:00pm
AUTO with A/C on is the correct way adjusting temp only.
Post #298146 10th Dec 2014 2:03pm
Dean
Yep - air con on and leave it on Auto Thumbs Up
(Gary beat me to it) 2006 FFRR TDV8 Vogue
Post #298147 10th Dec 2014 2:04pm
ebajema
Set to auto but 24/25 degrees otherwise I freeze to death Smile
Note, if the AC doesn't run for an extended period of time, the seals on the compressor especially can dry out and start to leak, losing coolant. That is likely what happened to my 4.2 AC system. MY 2010 5.0 SC Galway green and sand interior!!
Post #298150 10th Dec 2014 2:21pm
rr driver
Thanks for the info, 2011 5.0SC Santorini Black
Had
2.5 DHSE P38
Alfa Romeo
BMW
Post #298162 10th Dec 2014 3:03pm
Brian
Cheers for the info, so it's a/c on + auto and 22 it is for me (there is snow on the mountains now I might even go to 23) Cool
Post #298357 11th Dec 2014 1:57pm
ACK even the Mournes have snow Big Cry Big Cry Big Cry Big Cry FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #298375 11th Dec 2014 3:13pm
1959terry
United Kingdom 2015 Range Rover Vogue SE SDV8 Santorini Black
Leave it on. Prevents condensation and keeps the a/c seals tight.
If you are worried about fuel consumption then change you car!!!
Post #298417 11th Dec 2014 6:32pm
rr driver
so i drove to the west midlands and back, used the temp settings:
AC- On
Auto- On
Temp - 20-22- ( both left and right controls with air vents open) didn't find the car particularly warm.
Moved the temp on both to 25 the car became a little warmer i would describe it as being slightly warmer than tepid. -
am i not doing something right or is there something wrong? 2011 5.0SC Santorini Black
Had
2.5 DHSE P38
Alfa Romeo
BMW
Post #299005 15th Dec 2014 12:21am
What is the centre vent set to as I have it set to two red spots unless I'm on a long journey and then it goes to one blue spot to keep the interior a little bit cooler. FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #299006 15th Dec 2014 12:22am
Page 3 of 4 <1234>
