Home > Maintenance & Mods (L322) > Alarm going off and tail lights coming on. |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8610 |
how old is the battery? Random electrical gremlins are generally caused by a dodgy battery. would be the first place to look, if its not holding charge it can throw up some random errors, not sure on the lights coming on though..... There is nothing that can't be fixed with a hammer😜😜
5th Dec 2014 7:16pm |
Adev111 Member Since: 13 Jul 2011 Location: luton Posts: 6 |
The battery is only a year old. I also re-charged it using a CTEK charger and so not sure thats the problem.
5th Dec 2014 7:52pm |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3977 |
A mouse ate it's way into my wife's car and used to randomly set the alarm off overnight.
5th Dec 2014 9:10pm |
agree that is unlikely to be the battery if its only a year old.
5th Dec 2014 9:15pm |
Did bonnet switch. Disconnection, changed FSR, recharged battery, still same issue. Any other help really appreciated..? When I reconnect battery car starts no problem. So I then lock it, leave for a few hours and in the evening the alarm goes off...and message comes up Air suspension inactive, and the rear red lights come on. Bizarre ...
6th Dec 2014 12:14am |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35368 |
brake pedal switch seems to ring a bell.... ... - .- -.
6th Dec 2014 8:28am |
Have you checked the main cables of the battery, especially the negative cable connection to the chassis and the positive cable connections at the bulkhead. Also maybe check those cables at their clamp locations for corrosion (sometimes corrosion can go inside a clamp and is barely visible but can eat up the entire cable internally).
6th Dec 2014 11:57am |
Have you tried setting the alarm with the internal sensors disabled ie "pet in car mode" when you lock the car? |
6th Dec 2014 12:09pm |
Ok, some questions/comments
6th Dec 2014 1:57pm |
So problem still occurng by have noticed the break lights come on again whilst the car is locked. Any one know how to change the break light pedal switch a suggested. I think this is coming on then draining the battery resulting in the air suspension active message . Thereseems to be nothing wrong with suspension as drives fine suspension goes up and down as normal and the message clears by turning wheel method. If break pedal switch is an easy change then maybe worth trying before giving up and taking to the stealers..
8th Dec 2014 8:10am |
have a look in the WM , it might show you how to do it.. ... - .- -.
8th Dec 2014 8:17am |
