![]() | Home > Maintenance & Mods (L322) > Battery charge |
gregdav Member Since: 26 May 2014 Location: just north of stafford Posts: 1077 ![]() ![]() ![]() |
I think a lot of members òn here use the ctek battery charger, which I am looking into buying shortly. There are various ways to hook it up without disconnecting from the car. As I haven't got the 12s tow socket I will probably go for comfort fit under bonnet. There should be a few threads on here if you use the search.
Get yourself either a CTek MXS5.0 or MXS7.0 battery charger. Both perfectly capable of charging a battery on a TD6, the MXS7 is just slightly faster. No need to disconnect the battery from the car, you can either connect to the battery, jump posts, thro a permanently live accessory socket or a towbar connection. |
J90 Member Since: 02 Jul 2013 Location: Somewhere south of Bergerac Posts: 651 ![]() ![]() ![]() |
do you get a proper 3 pin plug with the CTek or do you have to buy it as an additional item? I only ask because all the pics and user instructions on the web show a two pin continental plug.
If you buy it in the UK you get a 13A 3pin plug as standard. |
netsonic Steve Member Since: 06 Oct 2010 Location: Sussex Posts: 165 ![]() ![]() ![]() |
I was thinking the same........what's happening to mean you need to charge a new battery........
Right that's a CTek on my Xmas list then. |
bazwd Member Since: 14 Feb 2013 Location: Bristol Posts: 26 ![]() ![]() ![]() |
Many thanks for your helpful replies. I will get a charger.
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8680 ![]() ![]() ![]() |
Sounds like you have some sort of battery drain issue going on there, either that or a charging issue. With that type of use the battery should be tip top. There is nothing that can't be fixed with a hammer😜😜
What you really need is a voltmeter of the type that plugs into a permanently live power socket so that you can see what is happening to the battery voltage whilst the car is standing and whilst driving. |
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6742 ![]() ![]() ![]() |
^ IIDTool can do that! |
Many thanks for the additional advice. I think it may well be a drain/not charging issue so will ask for this to be checked when it's in for its next service.
