Home > Maintenance & Mods (L322) > Battery charge |
gregdav Member Since: 26 May 2014 Location: just north of stafford Posts: 1077 |
I think a lot of members òn here use the ctek battery charger, which I am looking into buying shortly. There are various ways to hook it up without disconnecting from the car. As I haven't got the 12s tow socket I will probably go for comfort fit under bonnet. There should be a few threads on here if you use the search.
1st Dec 2014 7:41pm |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3972 |
Get yourself either a CTek MXS5.0 or MXS7.0 battery charger. Both perfectly capable of charging a battery on a TD6, the MXS7 is just slightly faster. No need to disconnect the battery from the car, you can either connect to the battery, jump posts, thro a permanently live accessory socket or a towbar connection.
1st Dec 2014 8:09pm |
J90 Member Since: 02 Jul 2013 Location: Somewhere south of Bergerac Posts: 651 |
do you get a proper 3 pin plug with the CTek or do you have to buy it as an additional item? I only ask because all the pics and user instructions on the web show a two pin continental plug.
2nd Dec 2014 7:04pm |
If you buy it in the UK you get a 13A 3pin plug as standard. |
2nd Dec 2014 7:41pm |
netsonic Steve Member Since: 06 Oct 2010 Location: Sussex Posts: 165 |
I was thinking the same........what's happening to mean you need to charge a new battery........
2nd Dec 2014 7:46pm |
Right that's a CTek on my Xmas list then. Travelling around in circles again. |
2nd Dec 2014 7:54pm |
bazwd Member Since: 14 Feb 2013 Location: Bristol Posts: 26 |
Many thanks for your helpful replies. I will get a charger.
1st Jan 2015 10:41pm |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8508 |
Sounds like you have some sort of battery drain issue going on there, either that or a charging issue. With that type of use the battery should be tip top. There is nothing that can't be fixed with a hammer😜😜
1st Jan 2015 10:47pm |
What you really need is a voltmeter of the type that plugs into a permanently live power socket so that you can see what is happening to the battery voltage whilst the car is standing and whilst driving. |
2nd Jan 2015 10:05am |
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6723 |
^ IIDTool can do that! Got - 2017 SDV8 Autobiography in Loire Blue
2nd Jan 2015 10:49am |
Many thanks for the additional advice. I think it may well be a drain/not charging issue so will ask for this to be checked when it's in for its next service.
5th Jan 2015 10:55am |
