Home > Maintenance & Mods (L322) > What is this part ?
markcaughey
Scotland 2006 Range Rover Vogue 4.4 V8 Buckingham Blue
What is this part ?
noticed a little oil around this part must be seeping out. this is the left hand side of the engine the one on the right appears fine
AJV8 4.4
Post #295314 26th Nov 2014 4:50pm
markcaughey
Anyone ? Range Rover Vogue 2006 4.4 AJV8 | Buckingham Blue | Parchment Leather | Supercharged Grill+Side Vents | CA02 HEY ( NOT 02 PLATE )
Post #295613 28th Nov 2014 9:54am
Oil temp? Discovery 4 HSE
Post #295615 28th Nov 2014 9:58am
markcaughey
Managed to get a few part numbers of the part and the clip GG23 On the part and 11246 on the clip. Tried googling the numbers but no joy. Taking the car to my local mechanic on Monday for him to take a look. Range Rover Vogue 2006 4.4 AJV8 | Buckingham Blue | Parchment Leather | Supercharged Grill+Side Vents | CA02 HEY ( NOT 02 PLATE )
Post #295867 29th Nov 2014 12:40pm
I'll have a guess, camshaft position sensor, is there one in the same place on the other side?? Pete
Post #295914 29th Nov 2014 5:34pm
markcaughey
yeah one on the right hand side. how do you go about removing it ? Range Rover Vogue 2006 4.4 AJV8 | Buckingham Blue | Parchment Leather | Supercharged Grill+Side Vents | CA02 HEY ( NOT 02 PLATE )
Post #295918 29th Nov 2014 5:43pm
Just had a google and I don't think it is camshaft sensor, they appear to be in the front of the engine, I can't see too well from your pictures, do a google image search on AJV8 engine sensor and see if any of them look like yours... if not pop down to the dealers, speak to the parts dept and get him to find it on the computer....
Could also try Jaguar Forums Pete
Post #295930 29th Nov 2014 7:01pm
markcaughey
i think your right with the camshaft sensor. been searching all night and can't find one that matches it. the only one i can see is the camshaft sensor for the bmw 4.4 which looks slightly different.
I was due to go and see my mechanic on Monday about this however if i can source the part myself is it easy to replace ? i have not got any error messages and the car seems to run fine, its just the oil residue around the sensor thats my concern
also i notice when looking at other camshaft position sensors they all seem to have a bolt or screw holding them in but this one does not is it just a case of twist to release it or something ? Range Rover Vogue 2006 4.4 AJV8 | Buckingham Blue | Parchment Leather | Supercharged Grill+Side Vents | CA02 HEY ( NOT 02 PLATE )
Post #295932 29th Nov 2014 7:11pm
markcaughey
like this one. they all seem to have to be screwed in however the one my car doesn't seem to have a screw Range Rover Vogue 2006 4.4 AJV8 | Buckingham Blue | Parchment Leather | Supercharged Grill+Side Vents | CA02 HEY ( NOT 02 PLATE )
Post #295941 29th Nov 2014 7:47pm
I'd leave it well alone if I were you, if it's something like a pressure release valve you could end up with a big bill on your hands.... personally I wouldn't bother with that small amount of moisture around it, if it gets any worse maybe do something...... Pete
Post #295965 29th Nov 2014 9:09pm
markcaughey
done a bit more digging and from what i can see this is the variable valve timing solenoid, which has been known to leak out oil due to a bad pcv. found this post on range rovers.net I have also noticed a slight suction type noise on accelerating. think i will replace the pcv and see how it goes from there. it seemed to sort this guys problems anyway.
http://www.rangerovers.net/forum/9-range-r...off-3.html Range Rover Vogue 2006 4.4 AJV8 | Buckingham Blue | Parchment Leather | Supercharged Grill+Side Vents | CA02 HEY ( NOT 02 PLATE )
Post #295991 29th Nov 2014 11:26pm
Yep... that looks like it, might as well change it then...
Very Happy Very Happy Pete
Post #295993 29th Nov 2014 11:34pm
markcaughey
fingers crossed that sorts the problem . now to find out how to change the pcv Confused Range Rover Vogue 2006 4.4 AJV8 | Buckingham Blue | Parchment Leather | Supercharged Grill+Side Vents | CA02 HEY ( NOT 02 PLATE )
Post #295996 29th Nov 2014 11:37pm
markcaughey
also found this on the jaguar forum saying that you can just pry the old seals out and fit new ones without removing the solenoid. I'm thinking this is more likely to be the probable as the solenoid on the right hand side is bone dry
http://www.jaguarforums.com/forum/xj-x308-...hat-99079/ Range Rover Vogue 2006 4.4 AJV8 | Buckingham Blue | Parchment Leather | Supercharged Grill+Side Vents | CA02 HEY ( NOT 02 PLATE )
Post #296003 30th Nov 2014 12:36am
markcaughey
will pick up new rubber seal tomorrow and let use know how i get on. this problem seems pretty common over on the juguar forums and usually its just the rubber seal that needs replaced. how do i know if the pcv is bad and need replaced ? the car runs, starts fine and fuel consumption is as it should be ?? Range Rover Vogue 2006 4.4 AJV8 | Buckingham Blue | Parchment Leather | Supercharged Grill+Side Vents | CA02 HEY ( NOT 02 PLATE )
Post #296101 30th Nov 2014 3:49pm
