Home > Off Topic - Other Cars > Low mileage Merc CL600
kam100
United Kingdom 2006 Range Rover Vogue SE Td6 Java Black
My 2003 Cl has two spots on the lower door area
Nothing else really showing
My 2006 Rangie has more noticeable bubbling.
I am well pleased with my Cl.
At the moment everything works.. If something too serious goes wrong..
At this kind of price level, it's less than the depreciation on any new car, so I will just bin it. Current: 11 Bmw 730Ld SE, RR Vogue SE 2006 3.0TD6, 06 Bentley Continental Flying Spur 6.0 W12.
http://WWW.MHCFINANCE.CO.UK - Vehicle Finance Services.
Kam@Mhasnain.co.uk : 0121 622 8122
MotorServ-UK Solihull & Coventry- Premium Auto Service Centres for Service/Repairs/Mot/Alignment/Tyres and Diagnostics. 0121 733 3387
http://www.motorservuk.com
Post #292634 13th Nov 2014 3:11am
All of that shape of CL's have plastic front wings and fiberglass boot, doors and bonnet are aluminium with a cast alloy frame, roof and rear wings are aluminium. It is riveted to a steel monocoque. The pre 2003 cars are prone to corrosion as Merc had to save big money in the early 2000's and skipped the cathode dip from the paint application process, they also skipped any underbody sealant, they all have plastic underbody panels, if you take them off it's bare steel with a thin coat of basecoat, not even any lacquer on it...
My 2000 CL had corrosion on the door, bonnet and rear arches, if it's fully ground out and sprayed with two pack etch primer it will hold the corrosion back for a very long time.
IMHO you are better off with the CL55C this is a 5.5 V8 with a supercharger, lighter engine than the V12 (which is very nose heavy) and for about £1500 you can get a reliable 650bhp (they are 500 standard)
There are plenty of specialists now sorting the expensive bits, I got my suspension pump rebuilt with a 24mth warranty for £400 as opposed to £1600 from Merc... most bits are shared with other Mercs and there are lots being broken as they are now worth more in bits...
Pick a nice post 2003 with the much better satnav and you have a great GT car.... Pete
Post #292668 13th Nov 2014 11:01am
alx
United Kingdom 2012 Range Rover Autobiography 5.0 SC V8 Nara Bronze
Doubt you can get extra 150 BHP for just £1500. A set of fitted exhaust manifolds alone will cost that much. Or did you mean £15000? That's more like it Very Happy
Post #293962 18th Nov 2014 6:11pm
A1GSS
I had a 2004 car albeit a standard CL500. Gorgeous.
 Graham
____
Gone: 10MY L320 RR Sport HSE, Ipanema Sand
Gone: 20MY Jaguar iPace HSE, Silicon Silver
Gone: 17MY RR Evoque SE Tech, Loire Blue
Gone: 08MY Discovery 3 XS, Stornoway Grey
Gone: 07MY FFRR TDV8 Vogue, Stornoway Grey
Post #293966 18th Nov 2014 6:25pm
Apparently, new supercharger pulleys, bigger injectors and a remap... £1500.... Pete
Post #293986 18th Nov 2014 7:07pm
alx
That won't result in 650 BHP. 70-75 BHP gain more likely but not 150.
http://www.mbclub.co.uk/forums/1775512-post3.html
Post #294005 18th Nov 2014 7:58pm
I read it on some tuners website a while ago... you are probably right... still be a darn quick car though.... Pete
Post #294021 18th Nov 2014 9:08pm
alx
Yep, pretty much. The trouble is you won't stop there. The higher the boost, the higher the temps. So you need a bigger or another intercooler. And a bigger pump. And a trunk mounted tank for better efficiency and to actually make use of all that power you're adding. Smile
Post #294326 20th Nov 2014 11:10am
