![]() | Home > Off Topic - Other Cars > Low mileage Merc CL600 |
kam100 Member Since: 25 Mar 2007 Location: Midlands Posts: 47 ![]() ![]() ![]() |
My 2003 Cl has two spots on the lower door area
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8514 ![]() ![]() ![]() |
All of that shape of CL's have plastic front wings and fiberglass boot, doors and bonnet are aluminium with a cast alloy frame, roof and rear wings are aluminium. It is riveted to a steel monocoque. The pre 2003 cars are prone to corrosion as Merc had to save big money in the early 2000's and skipped the cathode dip from the paint application process, they also skipped any underbody sealant, they all have plastic underbody panels, if you take them off it's bare steel with a thin coat of basecoat, not even any lacquer on it...
A1GSS Member Since: 24 Dec 2010 Location: Saffron Walden, Essex Posts: 1973 ![]() ![]() |
I had a 2004 car albeit a standard CL500. Gorgeous.
____ Gone: 10MY L320 RR Sport HSE, Ipanema Sand Gone: 20MY Jaguar iPace HSE, Silicon Silver Gone: 17MY RR Evoque SE Tech, Loire Blue Gone: 08MY Discovery 3 XS, Stornoway Grey Gone: 07MY FFRR TDV8 Vogue, Stornoway Grey |
Apparently, new supercharger pulleys, bigger injectors and a remap... £1500.... Pete __________________________________________________ 2014 L405 Autobiography SDV8 4.4 Loire Blue Ebony interior 2012 L322 Autobiography 5.0 Supercharged Ipanema Sand Sold 2011 L322 Vogue SE 4.4 TDV8 Baltic Blue. Sold 2002 L322 Vogue 4.4 V8 Epson Green (Fatty Offroader) Sold -Click for Project Fatty off roader- |
alx Member Since: 13 Jul 2014 Location: Beds Posts: 99 ![]() ![]() ![]() |
That won't result in 650 BHP. 70-75 BHP gain more likely but not 150.
I read it on some tuners website a while ago... you are probably right... still be a darn quick car though.... Pete
Yep, pretty much. The trouble is you won't stop there. The higher the boost, the higher the temps. So you need a bigger or another intercooler. And a bigger pump. And a trunk mounted tank for better efficiency and to actually make use of all that power you're adding. |
