![]() | Home > Technical (L322) > Suspension fault again and IID tool won't clear it |
Andy Member Since: 24 Feb 2009 Location: Shropshire Posts: 2944 ![]() ![]() ![]() |
Started getting the usual susp inactive message along with HDC inactive again. I try to clear the fault with the IID Tool but it won't clear. However when I switch off the ignition and turn it back on, the fault clears until I drive off. If I turn the steering wheel to the left, the message display shows "select neutral" and the lo range light flashes on the dash. The lo range led isn't present on the centre console and the fault shown in IID is "32 - canbus fault" indicating a break somewhere in the wiring.
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6419 ![]() ![]() |
Have you checked for any other faults - ABS, Steering Sensor etc., just in case it is something else causing the problem? .
Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2276 ![]() ![]() ![]() |
Battery not holding charge perhaps throwing up random faults? |
I haven't checked anything yet. It only started last night. It's where to start looking, which is the problem. |
Hi noddy,
Steve
Had a look today. Nothing obvious hanging off or worn. I do notice the conpressor runs on after switching off the ignition and when I start the car again, the fault clears. It's only when I drive over a speed bump that it faults again. I checked the values and the pump runs up to about 103psi but takes a while.
103 psi sounds a bit low, mine would vary from between 145 (when off road requested) and 185 when stable (and that was with the old knackered one!). .
Checked it again yesterday and it was 187psi which is a bit better
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35634 ![]() ![]() |
loose height sensor maybe.. ... - .- -.
I've checked both height sensors and the wiring to them. All seems to be ok.
Have you checked the compressor air exhaust filter/cone is not blocked? |
Meerbusch- it's a new battery.
was thinking based on the speedbump issue that all |
