Home > Technical (L322) > Suspension fault again and IID tool won't clear it
birchyman71
United Kingdom 2008 Range Rover Vogue TDV8 Java Black
Mine used to throw up the hdc, susp fault and the select neutral with transfer box symbol flashing , when turning left it turned out to be front left ABS sensor / wiring was busted , new abs sensor sorted it , it's to do with wheel speeds and when the wheel turns the worn wiring to the sensor stretches and goes open circuit ,
Post #299069 15th Dec 2014 2:58pm
Andy
That sounds exactly like mine, especially as it was clunking when braking downhill. I'll check that out- thanks!
Post #299070 15th Dec 2014 3:21pm
Andy
I'm almost certain it's the ABS sensor now. When I drove down my street last night with the icy roads, the ABS would not kick in & the car skidded. Just a matter of identifying which side has failed now
Post #301873 30th Dec 2014 6:15pm
