![]() | Home > My Range Rover > EDF - Mrs Edfors' shopping cart |
Probably why so many other drivers think FF drivers are all F |
Edfors Member Since: 26 Oct 2012 Location: Uppsala Posts: 168 ![]() ![]() ![]() |
Oh, regarding the F. Fanny's. The FF is really a womens car |
Tablets already existing, but that's not my question. The point in having it built in is that it's always there and don't ever need charging or get left behind somewhere... knowing my kids. |
Mate, I was the same with the 2006. It didn't have the DVD changer in at all and I went to quite some lengths (and money) to get it. Once it worked properly I realized that yes it is nice if it works, I mean the set up where each passenger can watch their own stuff is great, but going for a tablet (I think my eldest (11 coming on 12) would alright but my 4 yr old would probably forget) especially since they already have them (yes we succumbed too) is just easier.
vnitos Member Since: 18 Nov 2010 Location: pretoria Posts: 390 ![]() ![]() ![]() |
on the DVDs there are zones/areas indicated where these DVDs can be used. I have the same problem that some of my DVDs wont play in the car whilst others are working perfectly. |
vnitos has a point there, I had the same bloody issue. Even ripped DVDs with the region code removed didn't always play well either though. I think the DVD system may also be too old and it can't cope with the more modern DVDs. MY 2010 5.0 SC Galway green and sand interior!!
^^ As vnitos said I have real problems here with my UK car in Aus some work some don't I might get the IID on it but not very hopeful . 2008 MY Supercharged
Axle, I played around with the Faultmate forever (I have a lot of Oz/NZ DVDs from when I lived there) and no joy. Removing the region by ripping but that doesn't always work either as the DVDs sometimes still don't play. I think the RSE is just a crap system, outdated too much to cope with anything outside the narrow norm.
Your right about that the RSE system is just cr@p. I would probably think both twice and three times before ordering with a new vehicle. But now I bought EDF just because it plates, and to have my wife forgive me the 7 years of sorrow for the old hippo, and what a lucky car to be guaranteed well taken care of and a very long life.
I understand what you mean, like I said, I also wanted to get the systems working as intended on the 2006 and I did in the end. I would (after checking wiring and cabling and connectors) first do the lens (as you already said) and then the DVD changer itself. Also suggest to check the cabling to the screens although it is unlikely that they are the problem but still sometimes the connectors underneath the seats come out over time (usually undue tension on the cabling after the cabling got stuck).
I can tell because: - 1) The sidestick. 2) You have nothing to do - the plane flies itself. ![]() I take it you're a cockpit attendent? (Very envious by the way - cracking job). |
