Home > General > Vogue SE or Vogue with an 'extra' badge?! |
Welcome to the best and friendliest RR forum Robbo,
8th Nov 2014 7:08pm |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8524 |
The factory rse is recessed into the headrest, you can normally tell a vogue se by the 2 knobs either side of the clock. The vogue has none and the control for the heated seats is on the temp dials.
8th Nov 2014 7:14pm |
CEEGEE Member Since: 20 Mar 2013 Location: Yorkshire Posts: 685 |
The other big giveaway for an SE is perforated leather along with the cooled seats |
8th Nov 2014 7:23pm |
Robbo63 Member Since: 03 Nov 2014 Location: Midlands Posts: 28 |
Thanks for the replies:-)
8th Nov 2014 8:03pm |
It has the Venture Cam and some connector in the armrest that I'm assuming is for the phone, side steps, auxiliary heater and removable tow bar. Looking at the images in the Ad http://www.fullfatrr.com/forum/topic12944.html?highlight=vogue+se it looks identical apart from the seats, missing knobs either side of the clock and the badge misalignment.
8th Nov 2014 8:17pm |
You can check with LR, they will know how it left the factory but I can tell you, having owned an 07 VSE that the 2 knobs either side of the clock are for the heated and cooled front seats. Without this it would be a Vogue.
8th Nov 2014 8:31pm |
No venture cam on my vogue Dom.......
8th Nov 2014 8:56pm |
I think the TDV8 badge has been moved too as it doesn't match anything else on t'internet. I don't know if the headlights look round corners, is it obvious to see? I'll call the garage tomorrow and get the VIN and call it through. Does anyone on here have access to the LR records or can I just call LR?
8th Nov 2014 9:25pm |
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6729 |
No cooled seats = not an SE!
8th Nov 2014 9:53pm |
Many thanks for all of your replies, much appreciated. I'm quite dubious about its history so will give it a wide berth (although could buy it and kick off with them as a dealer!!)
8th Nov 2014 10:12pm |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7938 |
Be careful - just to confuse things, there's an SE as well as a Vogue SE It could be an SE with a Vogue badge added |
8th Nov 2014 10:14pm |
8th Nov 2014 10:57pm |
I assumed the "vogue" bit would be unnecessary in the context of the question Got - 2017 SDV8 Autobiography in Loire Blue
Yep. |
8th Nov 2014 11:16pm |
