Home > Maintenance & Mods (L322) > MOT/ Failed on brake lines |
Big Dave Member Since: 14 Jan 2014 Location: Preston, Lancs Posts: 19 |
Sal
6th Nov 2014 8:50pm |
SMUTT Member Since: 30 Jun 2014 Location: Cheshire Posts: 459 |
Yes I would say you are looking 4-5 hrs
6th Nov 2014 8:51pm |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6407 |
5 hours (he says reviewing how long it took him to do it himself - @ 3 days ) - I like to call it methodical
6th Nov 2014 10:16pm |
salb Member Since: 25 Feb 2012 Location: blackburn Posts: 332 |
thanks guys, yes i will be getting them done, no point cleaning and making it look pretty,
6th Nov 2014 10:27pm |
I sometimes wonder why we can't get the stainless steel braided lines you can buy for motorbikes. That stuff is much better, you can buy it on the roll (I did for my streetfighter conversion project) with the loose fittings, cut lines to length and install. Or the same outfits that sell the sets for motorbikes could do them for cars with the crimped connections.
7th Nov 2014 3:02am |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3970 |
Just coat your all brake pipes with grease and you won't need to replace them. |
7th Nov 2014 7:34am |
going to have a look at it today, see how bad they really are, might get them to change it to a advisory.
7th Nov 2014 7:45am |
Just to clarify, I don't advocate covering corroded brake pipes in grease, if they are corroded they need to be replaced.
7th Nov 2014 7:55am |
Hi, no i dint take it in that way, i need more time to change them as i will be changing them, and they have offered for
7th Nov 2014 8:14am |
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3774 |
Hi Sal,
7th Nov 2014 8:21am |
Hi Geoff,
7th Nov 2014 8:30am |
ok just got the quote back £700 to replace the brake lines i had to laugh really,
7th Nov 2014 9:22am |
Rosco Member Since: 20 Jan 2012 Location: Beyond the wall. Posts: 2575 |
Having followed this thread I think I have been massively undercharged for all the work/parts done to mine for once........... |
7th Nov 2014 9:24am |
Basic arithmetic seems to suggest they are charging £124/ hour for labour - £700-£80 = £620/5 = £124/hour. I would suggest that any decent indy would charge less than half that - try K Motors in Leyland (they did mine) or a more convenient indy to you, after all it is a pretty standard job. Geoff |
7th Nov 2014 10:25am |
