![]() | Home > Maintenance & Mods (L322) > MOT/ Failed on brake lines |
Big Dave Member Since: 14 Jan 2014 Location: Preston, Lancs Posts: 19 ![]() ![]() |
Sal
SMUTT Member Since: 30 Jun 2014 Location: Cheshire Posts: 459 ![]() ![]() ![]() |
Yes I would say you are looking 4-5 hrs
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6415 ![]() ![]() |
5 hours |
salb Member Since: 25 Feb 2012 Location: blackburn Posts: 332 ![]() ![]() ![]() |
thanks guys, yes i will be getting them done, no point cleaning and making it look pretty,
I sometimes wonder why we can't get the stainless steel braided lines you can buy for motorbikes. That stuff is much better, you can buy it on the roll (I did for my streetfighter conversion project) with the loose fittings, cut lines to length and install. Or the same outfits that sell the sets for motorbikes could do them for cars with the crimped connections.
Just coat your all brake pipes with grease and you won't need to replace them. |
going to have a look at it today, see how bad they really are, might get them to change it to a advisory.
Just to clarify, I don't advocate covering corroded brake pipes in grease, if they are corroded they need to be replaced.
Hi, no i dint take it in that way, i need more time to change them as i will be changing them, and they have offered for
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3866 ![]() ![]() ![]() |
Hi Sal,
Hi Geoff,
ok just got the quote back £700 to replace the brake lines i had to laugh really,
Rosco Member Since: 20 Jan 2012 Location: Beyond the wall. Posts: 2587 ![]() ![]() ![]() |
Having followed this thread I think I have been massively undercharged for all the work/parts done to mine |
Basic arithmetic seems to suggest they are charging £124/ hour for labour - £700-£80 = £620/5 = £124/hour. I would suggest that any decent indy would charge less than half that - try K Motors in Leyland (they did mine) or a more convenient indy to you, after all it is a pretty standard job. Geoff |
