Home > Technical (L322) > Strange heater blower problem - is it the FSR?
Tuts
Hi all, over the last week my cars heater seems to have lost its 'full power' setting on the blower/fans, they're definitely working only as you raise the fan speed you can hear that after about half way the fan Speed doesn't increase (even though the lights on the switch illuminate) . I have checked the fuses and done a battery reset but to no avail - does this sound like the FSR? 2003 Vogue 4.4 V8 Java Black
Post #290270 2nd Nov 2014 1:34pm
mjdronfield
Sounds like poss symptoms to me. It's not a costly item to replace, and a common failure point as you know, so would be my next step.
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #290272 2nd Nov 2014 1:51pm
I'm having issues with my new one similar to what you describe. My original problem was fan on full all the time, so I'm pretty sure I've introduce a new intermittent fault with the new one.
Just need time to get a replacement from the MD. Got - 2017 SDV8 Autobiography in Loire Blue
Post #290275 2nd Nov 2014 2:28pm
Tuts
Update!
Update! Ordered a new FSR and fitted it today, what a ball ache of a job! I was at some very odd angles under the footwell trying to get the Censored out, couldn't get the multi clip off, couldn't get it back in. I hope I don't have to do that again in a hurry. Still - it HAS fixed the problem so I was well chuffed when I turned the fans in full and they worked
The new one had more (but thinner) cones - hope it's a design improvement! Thumbs Up 2003 Vogue 4.4 V8 Java Black
Post #291599 8th Nov 2014 11:42am
Tuts
Thanks for the help guys, and for Dan uk 's old post about where the FSR is and how to remove it - he made it sound so easy to! Bow down 2003 Vogue 4.4 V8 Java Black
Post #291601 8th Nov 2014 11:43am
mjdronfield
Excellent result.
Should be set now for the winter......
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #291608 8th Nov 2014 12:08pm
