Home > Technical (L322) > Strange heater blower problem - is it the FSR? |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7816 |
Sounds like poss symptoms to me. It's not a costly item to replace, and a common failure point as you know, so would be my next step.
2nd Nov 2014 1:51pm |
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6733 |
I'm having issues with my new one similar to what you describe. My original problem was fan on full all the time, so I'm pretty sure I've introduce a new intermittent fault with the new one.
2nd Nov 2014 2:28pm |
Tuts Member Since: 24 May 2012 Location: Bishop’s Stortford, Herts Posts: 201 |
Update! Ordered a new FSR and fitted it today, what a ball ache of a job! I was at some very odd angles under the footwell trying to get the out, couldn't get the multi clip off, couldn't get it back in. I hope I don't have to do that again in a hurry. Still - it HAS fixed the problem so I was well chuffed when I turned the fans in full and they worked
8th Nov 2014 11:42am |
Thanks for the help guys, and for Dan uk 's old post about where the FSR is and how to remove it - he made it sound so easy to! 2003 Vogue 4.4 V8 Java Black |
8th Nov 2014 11:43am |
Excellent result.
8th Nov 2014 12:08pm |
