![]() | Home > Maintenance & Mods (L322) > C TEK |
You will need to make sure yours stay live after complete shut down about 20 minutes, depending on model some or all the power sockets go off line when the car is full asleep . 2008 MY Supercharged
ken Member Since: 22 Aug 2008 Location: On another forum Posts: 936 ![]() ![]() ![]() |
I use a Martin CTek plug in the tow socket |
appj62 Member Since: 07 Aug 2013 Location: Cheshire Posts: 424 ![]() ![]() ![]() |
The one in the boot area is also supposed to stay live if you haven't got a tow socket. Previous cars:
Joncey Member Since: 24 May 2014 Location: St Helier Posts: 53 ![]() ![]() ![]() |
Get your self one of these it will save you loads of messing around
Martin Site Admin Member Since: 24 Mar 2007 Location: Hook Norton Posts: 1665 ![]() ![]() |
Thanks for the recommendations guys |
J evro Member Since: 31 Aug 2014 Location: Kent Posts: 541 ![]() ![]() ![]() |
Thanks guys
Connect direct to the battery using the comfort charge method if no tow option |
Nomad Member Since: 26 Oct 2011 Location: Ringwood, Hants Posts: 300 ![]() ![]() ![]() |
I've used both the front cig lighter socket (mine was made live by the dealer when i bought the car) with cable out under door and also the rear accessory socket with cable out between upper and lower tailgate. Being doing so for years. Works really well. Often left charging for months at a time. Ctek are highly recommended. |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3977 ![]() ![]() ![]() |
I use a Ctek connected to a socket in the car without any problem at all.
I just connect my CTEK to the battery via the connector lead supplied with the CTEK |
A what ? |
Thanks, looking for an option where I do not have to lift the bonnet each time I want to go out in it ![]() |
Will check this when I get it back ![]() |
