Home > Technical (L322) > Mettalice wrattle on idling
Vogue Owner
United Kingdom 2012 Range Rover Vogue SE 4.4 V8 Java Black
Has any one had the following issue on a TD6 or other?
When idling there is an annoying mettalic rattling noise coming from underneath the car.
When driving its not there but if im in neutral and rev , the car revs and when it dies down i get this wrattle for a few seconds after.
The stealer has had it up on the ramp last time and said he couldnt find anything (mind you it was after i gave him a piece of my mind when i had my last expensive service)
Its really bugging me! CURRENT : FFRR 2012 4.4 TDV8
GONE : Discovery 4
GONE : BMW M5
GONE : L322 Range Rover
GONE : 2007 MITSUBISHI OUTLANDER
GONE : SAAB 9-3 VECTOR SPORT
GONE : BMW M3
GONE : SIERRA COSWORTH
GONE : LOTUS CORTINA
GONE : MK1 MEXICO
GONE : MK2 RS2000
Post #28566 20th Sep 2010 11:42am
Fox
I'm guessing the obvious would be the heatshield on the exhaust? Question
Mine was a bit loose near the back, but the MOT man refixed it while he was checking under there.
Post #28571 20th Sep 2010 11:57am
Vogue Owner
Yes that sounds about right - is there only one and are they easily accessible? CURRENT : FFRR 2012 4.4 TDV8
GONE : Discovery 4
GONE : BMW M5
GONE : BMW M3
GONE : MK1 MEXICO
GONE : MK2 RS2000
Post #28573 20th Sep 2010 11:59am
Fox
I think there are a few, but they are relatively easily accessible from underneath.
Post #28574 20th Sep 2010 12:07pm
stick the FFRR in 4x4 high mode and you can get under without creaking your neck .lol. ... - .- -.
Post #28578 20th Sep 2010 12:17pm
Rangie in oz
United Kingdom 2003 Range Rover Vogue Td6 Epsom Green
Hi Guys, dont know if this helps but I have the same probs with my TD6, not there all the time but sounds like a very heavy tappet noise, or a loud ball bearing in an aerosol can, have had a couple of places look at it and both say nothing to worry about it.
I have had a good look and traced it to the bosch fuel pump above the alternator, could be a return valve maybe.
I have managed to get it to go away by adding a good fuel additive but a couple of tanks later, its back.
Im doing well over 1K a week so any changes done at service can be picked up quickly. Ive just changed oil brand and have noticed the noise is not as loud but still there, it never gets worse though so maybe just a bosch quirk??
I think its the fuel pump as it only does it at tickover when its not under much load, but goes when you pick the revs up a bit.
the exhaust heat shield is good advice but mine only does this when just pulling away for a second or twon
hopes this helps
cheers
neil 03 TD6 vogue....Epsom, very nice
03 TD6 se....gone Sad
94 Vogue se....gone Sad
Post #28820 22nd Sep 2010 7:26am
could be a broken cat converter... ... - .- -.
Post #28854 22nd Sep 2010 9:30am
Vogue Owner
Finally managed to have a look underneath once the car had reached temperature.
It seems to be coming from the front exhaust box wrattling against something around it.
I pushed the box ever so lightly with a stick and revved the engine and the wrattle goes - so it would seem that the exhaust box is expanding so slightly that it is fouling on some underbody work.
May have to pop it into an exhaust shop and let them have a fiddle. CURRENT : FFRR 2012 4.4 TDV8
GONE : Discovery 4
GONE : BMW M5
GONE : BMW M3
GONE : MK1 MEXICO
GONE : MK2 RS2000
Post #29737 28th Sep 2010 4:16pm
Richcl
United Kingdom 2002 Range Rover HSE Td6 Zermatt Silver
I had the same coming from the front of my TD6, turned out to be loose front brake, backplate/shield.
Post #29738 28th Sep 2010 4:32pm
delamo
England 2007 Range Rover Vogue SE TDV8 Tonga Green
I remember having a rattle develop on my old TD6 for no particular reason - turned out to be the heat shield near the bulkhead for the exhaust downpipe had 'warped' and was touching the exhaust - must have been due to heat etc.
Quick and simple fix - a long prybar / screw driver was used to gently push/bend the shield back into position.
Hope yours is fixed as easily Thumbs Up
Post #29739 28th Sep 2010 4:37pm
DMRR
South Africa 2009 Range Rover Westminster TDV8 Stornoway Grey
If your Metallica is rattling, turn it down OR replace the rattly speaker Mad Land Rover Addict
XXXXXXXXXXXXXXXXXXXXXXX
Previous
XXXXXXXXXXXXXXXX
2009 5.0V8SC Autobiography
2006 4.2V8SC Autobiography
2004 4.4V8 Vogue
Post #29741 28th Sep 2010 4:42pm
