Home > Technical (L322) > Mettalice wrattle on idling |
Vogue Owner Member Since: 12 Jun 2008 Location: Braintree Posts: 234 |
Has any one had the following issue on a TD6 or other?
20th Sep 2010 12:42pm |
Yes that sounds about right - is there only one and are they easily accessible? CURRENT : FFRR 2012 4.4 TDV8
20th Sep 2010 12:59pm |
Fox Member Since: 02 Apr 2010 Location: Essex Posts: 2313 |
I think there are a few, but they are relatively easily accessible from underneath. |
20th Sep 2010 1:07pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35120 |
stick the FFRR in 4x4 high mode and you can get under without creaking your neck .lol. ... - .- -.
20th Sep 2010 1:17pm |
Rangie in oz Member Since: 25 Jul 2010 Location: liverpool Posts: 52 |
Hi Guys, dont know if this helps but I have the same probs with my TD6, not there all the time but sounds like a very heavy tappet noise, or a loud ball bearing in an aerosol can, have had a couple of places look at it and both say nothing to worry about it.
22nd Sep 2010 8:26am |
could be a broken cat converter... ... - .- -.
22nd Sep 2010 10:30am |
Finally managed to have a look underneath once the car had reached temperature.
28th Sep 2010 5:16pm |
Richcl Member Since: 23 Sep 2010 Location: Tewkesbury, Glos Posts: 1011 |
I had the same coming from the front of my TD6, turned out to be loose front brake, backplate/shield. |
28th Sep 2010 5:32pm |
delamo Member Since: 17 Mar 2010 Location: Beaconsfield, Bucks Posts: 1121 |
I remember having a rattle develop on my old TD6 for no particular reason - turned out to be the heat shield near the bulkhead for the exhaust downpipe had 'warped' and was touching the exhaust - must have been due to heat etc.
28th Sep 2010 5:37pm |
DMRR Member Since: 14 Apr 2010 Location: Northamptonshire Posts: 2027 |
If your Metallica is rattling, turn it down OR replace the rattly speaker Land Rover Addict
28th Sep 2010 5:42pm |
