Home > Maintenance & Mods (L322) > Fixed - HVAC Air quality sensor line fault
Page 2 of 3 <123>
ebajema
Very easy to do. MY 2010 5.0 SC Galway green and sand interior!!
Post #288079 22nd Oct 2014 9:59am
pld118
A simple unplug removes this part which the L322 Workshop Manual 2007-2010 describes as a "Pollution Sensor".
The part on our car was actually the following genuine BMW part/ number:
S 6411-8 391 470
Image of our BMW Air Con Air Quality Sensor (Recirculate) -
Post #288103 22nd Oct 2014 1:12pm
pld118
New sensor ordered from Dan @ Duckworths so hopefully all will be sorted Thumbs Up
Post #288243 23rd Oct 2014 9:55am
pld118
The new part arrived from Duckworth's yesterday (great service within 48 hours of placing the order, thank you Dan).
It arrives in a LR box and is in fact the identical BMW branded part that I pictured on this post.
Fitted the new part this morning, plugged in the IID tool, cleared the fault, switched everything off, started it all up again and the fault is now gone. Job done!
Thanks for the replies to the post which made this a quick and easy fix Thumbs Up
Post #288960 26th Oct 2014 10:52am
these simple fixes are great , its just finding the reason for the fault which is complicated.... ... - .- -.
Post #288963 26th Oct 2014 10:59am
calhighet
Can someone please show me where this sensor fits? struggling to find its mounting points.......
thanks
Post #360750 6th Dec 2015 9:44pm
SMUTT
United Kingdom 2002 Range Rover Vogue 4.4 V8 Oslo Blue
Behind the front grill, I think clip hear the landrover badge - but memory fading so could be wrong. Howard
____________________________________________________
2002 4.4 V8 LPG Tartarini
Have RSW AllComms in Cheshire J17 M6 - happy to help.
*Gone: Classic Vogue SE Auto V8 3.9 Sad
Post #360762 6th Dec 2015 10:20pm
mikeyyn
Sorry to resurrect this thread but does anyone know where this is on the 4.4 TDV8 MY 2011? It doesn't look like its in the same place, or at least I cant find it!
Post #440214 31st May 2017 12:24pm
tj2k
United Kingdom 2011 Range Rover Vogue SE TDV8 Ipanema Sand
Did you find out where that was?
Post #464373 13th Jan 2018 10:15am
not 100% sure but i think its behind the drivers door mirror... ... - .- -.
Post #464384 13th Jan 2018 11:13am
tj2k
Thanks for the response - sincerely appreciated. It’s not behind the drivers door mirror though 😁
After I posted, I went and had another good look; on a UK car, it’s on the right hand side about half way up/down the rad assembly, on the back, next to the large air pipe that comes down from the air cleaner box.
To get access, the air cleaner whole box really needs to come out (a lot easier than it sounds) as well as the upper part of the air pipe u-bend from the air cleaner - the right angled part.
The part push-clips in place. Very easy really, just looks more involved than it is. I’ve taken pics pics of when I did mine this morning & will post here shortly after my bacon roll! Thumbs Up
Post #464394 13th Jan 2018 12:30pm
tj2k
My pics need a lil work so will re-post’em
Post #464401 13th Jan 2018 1:43pm
Lee Marsh
England 2006 Range Rover Vogue Td6 Zambezi Silver
Unnecessary quote removed
Hope you enjoyed the bacon roll. Any luck with those pics? Wink
Post #477636 6th May 2018 4:53pm
Sharpy1980
United Kingdom 2010 Range Rover Vogue TDV8 Stornoway Grey
I changed mine today and took a pic if it helps anyone else
 L322 4.4 TDV8 Current
L320 3.6 TDV8 Going
L322 3.0 TD6 Gone
Disco 2 Td5 Gone
Defender 90 Gone
Freebie Td4 Gone
Disco 1 200tdi Gone
Post #520894 6th Jul 2019 8:41pm
pcourtney
I did mine today, it seems they do fail and if using IID Tool - this error is thrown up
ATC-Heat / Cool
0x30 Air Quality Sensor line fault
my old part was also stamped BMW - BMW part/ number: S 6411-8 391 470
Post #558422 20th Jun 2020 11:47pm
Page 2 of 3 <123>
