![]() | Home > Maintenance & Mods (L322) > Fixed - HVAC Air quality sensor line fault |
Sharpy1980 Member Since: 20 Nov 2016 Location: Kent Posts: 55 ![]() ![]() ![]() |
You can use a long screwdriver to move it off it’s mount with wire still attached then unclip the wire when you can get your hands to it, if you look at the new one you will see what way to push the sensor to move it off it’s mount L322 4.4 TDV8 Current
Naki Member Since: 04 Feb 2021 Location: Boston, South Lincolnshire Posts: 34 ![]() ![]() ![]() |
I too am looking for where this “air quality sensor” is supposed to fix in? It’s dangling loose on my 2007 3.6 TDV8.
