Home > In Car Electronics (L322) > Touch Screen issues |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35439 |
whats your battery like rory?.....and is there any moisture in the rear cubby hole. ... - .- -.
14th Oct 2014 5:57pm |
RoryM Member Since: 02 Mar 2013 Location: Ireland Posts: 51 |
Hi Stan, battery is fine and entire boot and cubby holes are completely dry. |
14th Oct 2014 6:00pm |
did you check all the connections ... ... - .- -.
14th Oct 2014 7:06pm |
markcartlidge Member Since: 18 Mar 2013 Location: Nr Winslow, Buckinghamshire Posts: 120 |
Whats the image like when you change source ie. TV, reversing camera Sat nav etc? The image looks like it is garbled data which means the LCD is may be working but what is sending it the data is broken or being corrupted.
14th Oct 2014 7:19pm |
Its the same in all screens. the touch functions work, Ie, it will change radio station but you just cant see it. I disconnected the fibre optic cables too and that only cut out the radio but not the fuzzy screen. |
15th Oct 2014 12:37pm |
does the pattern on the screen change with time or with switching source or is it fixed all the time? |
15th Oct 2014 1:00pm |
its the same all the time. its not frozen if you know what I mean. it flutters a bit for what of a better word. |
15th Oct 2014 1:04pm |
Looks like you need to replace the head unit or LCD. You might be able to get it repaired, there is a place in USA who might do them but you probably want somewhere more local. If you have no luck with it you can send it to me to look at but not having seen the inside of one I would be wokring blind. |
15th Oct 2014 1:54pm |
hmmmm. its happened about 5 or 6 times now. think I'll just get rid of the feckin thing. tis driving me mental. |
15th Oct 2014 2:09pm |
if it is intermittent then it could be heat related. |
15th Oct 2014 2:26pm |
