Home > In Car Electronics (L322) > Touch Screen issues
RoryM
Ireland 2008 Range Rover Vogue TDV8 Santorini Black
Touch Screen issues
Can anyone tell me what's going on here with my touch screen? its very intermittent. The touch function of the screen still works. This pic below is with the radio on. Restarting the car usually clears it.
Rory.
Post #286445 14th Oct 2014 5:54pm
whats your battery like rory?.....and is there any moisture in the rear cubby hole. ... - .- -.
Post #286446 14th Oct 2014 5:57pm
RoryM
Hi Stan, battery is fine and entire boot and cubby holes are completely dry.
Post #286447 14th Oct 2014 6:00pm
did you check all the connections ... ... - .- -.
Post #286456 14th Oct 2014 7:06pm
markcartlidge
Whats the image like when you change source ie. TV, reversing camera Sat nav etc? The image looks like it is garbled data which means the LCD is may be working but what is sending it the data is broken or being corrupted.
If you can get some pictures of differnet inputs you might be able to narrow it down.
Post #286462 14th Oct 2014 7:19pm
RoryM
Its the same in all screens. the touch functions work, Ie, it will change radio station but you just cant see it. I disconnected the fibre optic cables too and that only cut out the radio but not the fuzzy screen.
Post #286567 15th Oct 2014 12:37pm
markcartlidge
does the pattern on the screen change with time or with switching source or is it fixed all the time?
Post #286572 15th Oct 2014 1:00pm
RoryM
its the same all the time. its not frozen if you know what I mean. it flutters a bit for what of a better word.
Post #286574 15th Oct 2014 1:04pm
markcartlidge
Looks like you need to replace the head unit or LCD. You might be able to get it repaired, there is a place in USA who might do them but you probably want somewhere more local. If you have no luck with it you can send it to me to look at but not having seen the inside of one I would be wokring blind.
Post #286595 15th Oct 2014 1:54pm
RoryM
hmmmm. its happened about 5 or 6 times now. think I'll just get rid of the feckin thing. tis driving me mental.
Post #286597 15th Oct 2014 2:09pm
markcartlidge
if it is intermittent then it could be heat related.
Post #286602 15th Oct 2014 2:26pm
