Home > Technical (L322) > TD6 Engine Upgrade to M57 BiTurbo? Has it been done? |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3657 |
Hi all, I was having a discussion with my neighbour about the M57 thats in my FFRR and his 530 Touring, and we got on to the subject of 'MORE POWER!!!!!!!!'. And it got me to thinking if anyone has tried to fit the BiTurbo, or TriTurbo engines from a later X5 / X6? From what I can make out the BiTurbo produces 282 hp / 430 lb.ft and the TriTurbo produces 376 hp / 550 lb.ft!
12th Oct 2014 11:11pm |
KurtVerbose Member Since: 08 Aug 2010 Location: Les Arses Posts: 5848 |
Or for probably a lot less money and certainly a lot less hastle you could just sell it and get the TDV8? |
13th Oct 2014 7:03am |
RCusden Member Since: 12 May 2012 Location: NarberthPembrokeshire Posts: 186 |
Could you just put the twin turbo's on the td6 and get the ecu remapped to accept them ? |
13th Oct 2014 7:18am |
And blow up the gearbox driving it out of the shop MY 2010 5.0 SC Galway green and sand interior!!
13th Oct 2014 8:38am |
It has a different block with a different capacity. The later ones also switched to an aluminium block. |
13th Oct 2014 9:20am |
I agree that the ECU's would be the main headache to the mod, not being up to date with the X5 I'm not too sure how much they have evolved from 2005 / 6 when the TD6 was dropped in favour of the TDV8. Knowing my luck its a straight nut and bolt job for the touch screen nav cars and a complete brainache for those of us with the non touch nav
13th Oct 2014 1:04pm |
In theory the early twin turbo ones use the same block and head so it would be a case of taking the exhaust manifold and inlet manifold and pipe work from one and fitting it.
13th Oct 2014 1:19pm |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8500 |
Just a point on the tdv8 being a ford engine, a bit ot I know, but although built by ford they are basically a psa 2.7 v6 diesel witg 2 extra cylinders as far as I can tell. So far from being designed by Americans who wouldn't know a good Diesel engine from adam, they were effectively designed by the french....... Who seem to know diesels pretty well.....
13th Oct 2014 7:20pm |
Correct hdi engines even though wiki will state slightly diff they were meant to be jointly developed with psa, but psa did the real design and jlr just made them. Also bmw use the 1.6 in their mini as do ford, Volvo.... They are good engines when looked after but the key to them is good fully synth oil, ideally at half intervals.
13th Oct 2014 7:28pm |
Ok so its a French engine built in the UK by Americans, How many chiefs do you need?? M57 build by Germans, at home, with no help from the rest of the world! The Germans also make some of the best Diesel engines, especially when it comes to the large Marine units.
13th Oct 2014 8:09pm |
Not knocking the M57, have had a couple of them in 5 series. Cracking bit of kit in twin turbo form when I had it in 535d, the 530 gave me a bit of trouble
13th Oct 2014 8:24pm |
The problem with the bigger turbo and injectors is that it would have a much higher torque spike hitting the transmission.
13th Oct 2014 8:39pm |
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 962 |
It’s always puzzled me that the BMW 730d (E38 shape from 1998 to 2001) used the M57D30 engine (181bhp/410Nm) but with the far superior ZF 5HP24 transmission and not the GM 5L40-E unit used in the X5 and L322 with the same engine.
13th Oct 2014 10:56pm |
Laurie915 Member Since: 11 Sep 2011 Location: Canberra Posts: 72 |
Have you looked at a Garrett Ball-bearing turbo setup ? a very good increase in power, but a lot better in torque with a lower and wider spread !!!
14th Oct 2014 9:54am |
