![]() | Home > Technical (L322) > TD6 Engine Upgrade to M57 BiTurbo? Has it been done? |
| miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3669
Hi all, I was having a discussion with my neighbour about the M57 thats in my FFRR and his 530 Touring, and we got on to the subject of 'MORE POWER!!!!!!!!'. And it got me to thinking if anyone has tried to fit the BiTurbo, or TriTurbo engines from a later X5 / X6? From what I can make out the BiTurbo produces 282 hp / 430 lb.ft and the TriTurbo produces 376 hp / 550 lb.ft!
| KurtVerbose Member Since: 08 Aug 2010 Location: Les Arses Posts: 5848
Or for probably a lot less money and certainly a lot less hastle you could just sell it and get the TDV8? |
| RCusden Member Since: 12 May 2012 Location: NarberthPembrokeshire Posts: 186
Could you just put the twin turbo's on the td6 and get the ecu remapped to accept them ? |
| ebajema Member Since: 24 Mar 2011 Location: New Plymouth Posts: 4782
And blow up the gearbox driving it out of the shop |
It has a different block with a different capacity. The later ones also switched to an aluminium block. |
I agree that the ECU's would be the main headache to the mod, not being up to date with the X5 I'm not too sure how much they have evolved from 2005 / 6 when the TD6 was dropped in favour of the TDV8. Knowing my luck its a straight nut and bolt job for the touch screen nav cars and a complete brainache for those of us with the non touch nav |
| kingpleb Member Since: 07 Jun 2011 Location: Maybe here. Maybe there, I get everywhere! Posts: 8455
In theory the early twin turbo ones use the same block and head so it would be a case of taking the exhaust manifold and inlet manifold and pipe work from one and fitting it.
| northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8788
Just a point on the tdv8 being a ford engine, a bit ot I know, but although built by ford they are basically a psa 2.7 v6 diesel witg 2 extra cylinders as far as I can tell. So far from being designed by Americans who wouldn't know a good Diesel engine from adam, they were effectively designed by the french....... Who seem to know diesels pretty well.....
Correct |
Ok so its a French engine built in the UK by Americans, How many chiefs do you need?? M57 build by Germans, at home, with no help from the rest of the world! The Germans also make some of the best Diesel engines, especially when it comes to the large Marine units.
Not knocking the M57, have had a couple of them in 5 series. Cracking bit of kit in twin turbo form when I had it in 535d, the 530 gave me a bit of trouble
The problem with the bigger turbo and injectors is that it would have a much higher torque spike hitting the transmission.
| RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 1042
It’s always puzzled me that the BMW 730d (E38 shape from 1998 to 2001) used the M57D30 engine (181bhp/410Nm) but with the far superior |
| Laurie915 Member Since: 11 Sep 2011 Location: Canberra Posts: 72
Have you looked at a Garrett Ball-bearing turbo setup ? a very good increase in power, but a lot better in torque with a lower and wider spread !!!
| All times are GMT |
