Home > Maintenance & Mods (L322) > Sidesteps
Tim in Scotland
Location: Somewhere between here and there, if not then I'm all at sea or at home in Scotland
2010 Range Rover Vogue TDV8 Stornoway Grey
Sidesteps
A week on holiday with my elderly parents in the car has highlighted a problem that didn't exist with my RRS's - my 5ft tall (short??) 82 year old mother has a lot of problems getting into the FFRR even at access height due to the smaller rear door aperture of the FFRR. I HATE side steps on Range and Land Rovers (except on Defenders!) but if I am to be an older person's taxi driver then I'm going to have to consider a set just for mother to get in and out of the car as both of them will soon be at the age when they have to hand back their licences.
So, fixed or deployable (motorised)? tubular or conventional. Have been warned off the deployable/ remote control ones because if you need to call out the AA/ LRA they have problems jacking up cars with deployable steps and claim they have to recover the car back to a dealership to remove the entire mechanism due to risk of damage if they try to jack the car up without removing them. 2018 Mini Countryman Cooper S E All4 PHEV in Melting Silver - it’s whisper quiet in EV and polluter modes
Post #28510 19th Sep 2010 7:41pm
Macdaddy
2003 Range Rover Autobiography 4.4 V8 Java Black
If moneys no object then I'd choose motorised.
They remove easily with just 4 bolts. They do have to be removed to jack up the car which is a pain if you've a flat on the motorway etc.
While side bars look good I don't think they'd suffice for the elderly to use safely.
Fixed is probably the best way forward in your case. TDV8 HST Sport **Current**
4.4 V8 Autobiography and 22" wheels **Gone**
Post #28511 19th Sep 2010 7:50pm
darrenmax
Belgium 2003 Range Rover Vogue Td6 Giverny Green
keep one of these in the boot Rolling with laughter
 2002 td6 vogue, 06 supercharged facelift
Post #28514 19th Sep 2010 8:04pm
delamo
England 2007 Range Rover Vogue SE TDV8 Tonga Green
What a crate idea! Whistle
Post #28515 19th Sep 2010 8:05pm
Nickj
2003 Range Rover Vogue SE 4.4 V8 Java Black
Ah come on! I think your MILKING that!!
Post #28517 19th Sep 2010 8:10pm
Tim in Scotland
Darren we resorted to using something very similar to that, a plastic fish box we found on a beach, it was a little lower and a lot wider and just about right for the job but not very elegant Embarassed Embarassed 2018 Mini Countryman Cooper S E All4 PHEV in Melting Silver - it’s whisper quiet in EV and polluter modes
Post #28527 19th Sep 2010 9:13pm
The side tubes are NO good as steps Tim, you can't get enough foothold and of course they are round and probably slippery when wet.
I think your only choice is fixed side steps, get them from Powerful UK via eBay for about £275 and easy enough to fit at home.
Might need to ring them and check they fit the 2010MY Discovery 4 HSE
Post #28534 19th Sep 2010 10:10pm
dan_uk_1984
RE: Jacking Points
You can always lift using the workshop jacking points. The RAC should be using these anyway as these are the ones LR recommend for use with hydraulic jacks
The side jacking points are hopeless and if you've ever used them you'll know you have to lift the car 5 times higher than direct at axle point die to the articulation.
L322 Front Jacking Point by d86cfv, on Flickr
L322 Rear Jacking Point by d86cfv, on Flickr
Post #28537 19th Sep 2010 10:59pm
Bosun
United Kingdom 2010 Range Rover Vogue SE TDV8 Java Black
Powered access step designed for Range Rover
Hello,
I have the deployable side steps on my new vehicle and therefore have no use for an electrically powered step that may well help you.
I bought it with the intention of my partner's elderly Nan to use, but commitments prevented my having enough time to do the work, so I can't comment on it's operation.
As I remember, the unit has an articulating lever system and a footplate of substantial build in the order of 18" square. The attached cabling looks of good quality and is approximately 16mm'
I believe that the footplate folds well out of the way in normal running and is driven into the user position by activation of a switch.
Since the vehicle battery is on the nearside, this should make any additional wiring or routing quite a simple task.
If you summon up the old brain cells it ought to be possible to have it only operable with the nearside rear door open, rather than any or no doors at all.
I'm away aboard ship at the moment, but should be back home in a little under a fortnight and may be able to send details.
Regards,
Bosun It's no mistake that Man's best friend can't talk!
Post #28539 20th Sep 2010 3:39am
iT LAD
Darren, I think you lost your bottle...
Post #28743 21st Sep 2010 1:59pm
