Home > Maintenance & Mods (L322) > 6 speed zf gearbox oil change
martylennox
Hi Guys,
I've read the wiki for the gm 5 speed gearbox oil change, is there a different procedure for the zf 6 speed box? I've just ordered a kit and was going to do it myself.
Thanks in advance guys.
Post #285195 9th Oct 2014 8:57am
Can be tricky to set the levels as the temp needs to be correct when filling it up. I bought the parts and got my local dealer to do the swap. Charged me £95 +vat, which seemed easier than scrubbing find under the car covered in oil! There is nothing that can't be fixed with a hammer😜😜
Post #285210 9th Oct 2014 10:47am
RRPhil
Phil
Post #285220 9th Oct 2014 11:22am
ebajema
In Holland (and probably also in the UK) they sell these big plastic "tubs" to put your washing machine in. In case it leaks it holds quite a bit of water.
Mine is being used for oil changes and because they are not very high (say about 10 cm) they are easy to work with (did the Suzuki B-King a few days ago).
They are quite cheap and last a long time so it could save you a bit of money if you do it yourself and keep your driveway clean as a whistle Smile MY 2010 5.0 SC Galway green and sand interior!!
Post #285223 9th Oct 2014 11:35am
JST
England 2012 Range Rover Westminster 4.4 V8 Stornoway Grey
i did mine two weeks ago, very simple and easy to do, funnel and hose pipe are ideal for adding new fluid to box. Cheers
James
Post #285338 9th Oct 2014 6:58pm
ebajema
I used a cheap pump up spray can (10 liter type) one normally uses for garden pesticide spraying or foam washing type work. I used it heaps of times to fill the gearbox of the 2006 when I had the blown cooler issue. Very easy to do. Paid about 35 Euro for one of those. MY 2010 5.0 SC Galway green and sand interior!!
Post #285420 10th Oct 2014 4:36am
