Home > Maintenance & Mods (L322) > 6 speed zf gearbox oil change |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8501 |
Can be tricky to set the levels as the temp needs to be correct when filling it up. I bought the parts and got my local dealer to do the swap. Charged me £95 +vat, which seemed easier than scrubbing find under the car covered in oil! There is nothing that can't be fixed with a hammer😜😜
9th Oct 2014 10:47am |
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 962 |
9th Oct 2014 11:22am |
In Holland (and probably also in the UK) they sell these big plastic "tubs" to put your washing machine in. In case it leaks it holds quite a bit of water.
9th Oct 2014 11:35am |
JST Member Since: 12 Dec 2013 Location: Somerset Posts: 488 |
i did mine two weeks ago, very simple and easy to do, funnel and hose pipe are ideal for adding new fluid to box. Cheers
9th Oct 2014 6:58pm |
I used a cheap pump up spray can (10 liter type) one normally uses for garden pesticide spraying or foam washing type work. I used it heaps of times to fill the gearbox of the 2006 when I had the blown cooler issue. Very easy to do. Paid about 35 Euro for one of those. MY 2010 5.0 SC Galway green and sand interior!!
10th Oct 2014 4:36am |
